To throw you another curve. Hitting reply on the laptop in chrome gave me a 3x wide screen running windows 7. Running ie on another computer using xp with widescreen gave me the same result. I am now on another computer running windows xp on ie using a STANDARD (not widescreen) monitor and the page is fine. Display is 1280x1024 on standard monitor. I know that my display on a widescreen is 13??x780 and it will not go higher than 780 on one. Not sure about the laptop. Standard monitor running 1280x1024 is good, widescreen monitor running 13??x780 is not. Obviously screen size affects it but there is something in the page coding also that is not meshing with certain resolutions. I am of absolutely NO MORE help.
Go into your look and layout prefs and uncheck the box that makes the newest posts at the top.
Done did. Is it a track day today 'cause you're a little slow?
Time to pull the motor for the winter.
