Linux Mint 11 Rulez....
how did you confirm this? Cylinder leakdown test or compression test? A broken ring should cause a lot of "blow by"I had a buddy with a small block Chevy that would blow the dipstick out! I'm guessing you should see smoke/oil coming out of the breather cap on the VC.
well I am also sorry to hear of this. Ring failure is not very common. I wonder what happened.
unless you want more power.fd
That's what we're going for...
Compression test.
A faulty had gasket could lead to abnormal compression test results too correct?
