I used 1/2 a gallon of 2K with 3 coats on everything but a door made by ching wong-150$, I have a gallon of base coat-240$ quart of sealer-100$ Gallon of Clear Coat-300$ If your going to paint/prime it yourself you might want various sanding pads-i used hookit 2's which are expensive$$/maybe a DA sander/ good 3M green tape think its like 3$ a roll?-paint sticks/free-mixing cups/2$, screened funnels,gallon of degreaser-35$,Tack rags1$,wet sanding block 4-10$ some 600 grit wet sanding paper-30$,Hardener/Laquer/Tiger Seam sealer15$ a TUBE!!!/can of guide coat for primer-5$/Self Etch Primer for bare steel8$/ any stripes you need fine line tape/ I bought 2 quarts of POR 15 for the underside at 40$ a piece and over that laid down 3 coats of Raptor U-POL 140$ a kit includes gun, + 1 bottle 20$...ect..ect..
It can go on and on, the base coat price will depend on the color/availibility in your area, I bought all my stuff at Sam's Auto Body-
Materials usually cost 800-2000$, And i have seen a body shop charge 5,000$ for a spray job on a buick all they did was pressure wash the car and lay down paint...probably started to flake on the ride home lol.
