Linux Mint 11 Rulez....
Rod, it sounds like after this "tune-up" you'll be running like a 351 W. with new plugs.
Oh Rod, you're such a wimp. You know darn well that you'll be out and about in no time right after the surgery. Hell, I wouldn't even have enough time to fly out and drive your car before you'll be back at home.
Be careful, they may deny any more warranty work.....Good luck....that nose and a Q-tip sounds like fun..the surgery may be a relief from that.
They said 5-7 days in hosp--that alone will suck---the car needs driven so have at it---it drives pretty good since I put open trackers roller spring perches and lowering springs on the front--also 15 inch tires made a difference. As for the wimp part I will whine about that later. I have posted before my fixes--ruptured disc in lower back(micro surgery to fix) shoulder seperation from wreck(nine days intensive care ), both knees scoped, left arm broken in 5 places (3 different accidents)bariatric surgery, 2 hernias repaired, cracked tail bone, carpal tunnel surgery, appendicts (sp.?) removed,beneign tumor removed from chest(3 days hosp there)pnemonia twice, broken nose, 2 teeth knocked out, left thumb broken, knocked out and skin graft on hand from wreck in april. vasectomy, and I probably forgot some. I have had about enough surgery and fixes.
WOW! You should be change your screen name to SA6MDM (aka Steve Austin, 6 Million Dollar Man)!!! "We can rebuild him, make him faster, stronger......."Good luck with the surgery!
