Agree with mid. Do you have enough slack in the wiring to disconnect the switch from the dash for a easier view of the connections to the back of it?
If I do remove the switch for testing, does the case of it need to be grounded, since this normally makes contact with the dash?
Bill,Keep in mind that at this rate you'll be done in no time with this project. Then what are you going to do? Sloooowwww down.
You're so right! Just imagine what would happen if I were to do something like... oh... rebuild the motor? :-P Sent from my Droid using Tapatalk
Wha..? Is it fixed?
For 1973, there are two wires off of the ignition: the pink resistor wire that goes to the green junction box behind the fuse box, and a green/red wire that goes to the fuse box itself.
Do I need to cut the pink wire at the ignition and replace it? If so, how do I get the ignition out of steering column?
The ign switch is mounted onto the outside lower part of the colume and is held on by 2 nuts.The resistor wire is in the main harness loom located behind the inster cluster.Remove the cluster and unwrap the harness and look for a looping pink wire.
