For 1967/68, there is no other line that is only hot with the key in RUN position and cold in all other positions. It would be nice to be able to splice another line to the coil and simply remove the existing line off of the coil. Good luck!
This is curious since I spliced in awhile ago to the green w/red stripe wire coming from the ignition switch in order to provide 12-volt switched power to the choke. It's always worked. (Wire 904 on the schematic) For what it's worth, the car is also running a single-wire alternator, so the typical regulator circuit isn't attached. Sent from my Droid using Tapatalk
Have you swapped out the Ingiter yet?
Not yet, but I do have a new one here. That's why I was asking if anyone knows the test for a dead Ignitor. I'm thinking it might be a lack of continuity across the leads, unless someone knows of another test. Tomorrow, I'm going to measure each unit and see what I get. Sent from my Droid using Tapatalk
66benchcoupe: With an ohm meter you should measure less than 1 ohm resistance to ground between the engine block and the negative post on the battery.
cmayna: How about pulling the coil wire from the dizzy and ground it while cranking to see if you are getting spark to the dizzy
SAC69: A total stab in the dark: could this be related to a bad voltage regulator or does that only regulate the alternator-to-battery current flow?
Mach1Rider: Try turning key to On and jump the starter sol to crank eng. Does it run? yes, Then trace the brown wire from the sol back to coil + wire for connection.
The lack of voltage at the brown wire (the "I" post) when the key's in the ON position makes me think the problem does lie with the brown wire. Does that make sense? If so, I'd have to go back and look at the wire at where I spliced in the resistor wire bypass. I didn't touch the "brown wire side" of the plug connector, but maybe it's come loose or disconnected (???)
Here's what I think is happening: when cranking, the starter solenoid is sending full voltage to both the coil and the starter. The connection to the starter is pulling too many amps, bringing the voltage down, but still good enough for the engine to catch. When you release the key, the battery voltage is now low due to amperage being pulled by the coil and its now too low by itself and the internals of the starter solenoid to keep the engine going.
That's an interesting theory. But wouldn't the alternator supply the voltage needed to run the engine? While the engine is cranking the voltage at the battery should drop to 8 volts or so (I've noticed this from chasing down starter gremlins in the past). If it drops any lower then maybe a new starter or putting to battery on a charger overnight is in order.Robert
That's an interesting theory. Robert
