Author Topic: Gauges go dead after driving  (Read 525 times)
Offline Dne'
« on: August, 14, 2011, 06:42:52 AM »
I guess something had to go wrong sooner or later, but I'll start my stang, all the gauges read the way they're supposed to, then after about 10 minutes or so, all the gauges creep down to nothing.  I had installed an electronic contant voltage regulator before putting my instrument panel in; never had a problem until recenty.  Sometimes I'm lucky and the gauges don't go dead, but most the time do. Like the fuel gauge goes empty, not towards the full.  Is this a faulty constant voltage reg?  The voltage output from my 100 amp Tuff Stuff alternator puts on 14-15 volts on my under the dash voltmeter.  Would I have too much voltage from my alt?
dne'  ; )
photo is a couple years old~
Offline Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
Re: Gauges go dead after driving
« Reply #1 on: August, 14, 2011, 11:04:25 AM »
Sounds like the output of the CVR went kaput to me...
Panama City, FL
Offline Dne'
« Reply #2 on: August, 14, 2011, 12:31:48 PM »
Hi Midlife! Things I have to do so say HI!  Darn thing didn't last very long!  oh well! Here I go to start looking for another one.
thanks,
Offline blue65coupe
  • Banned
  • where's my short bus
« Reply #3 on: August, 15, 2011, 10:40:00 AM »
Not an electrical expert but could there be a grounding issue?
Duane
Offline Midlife
  • DOM
« Reply #4 on: August, 15, 2011, 02:12:44 PM »
At the CVR, perhaps, but if voltage out from the CVR is good, the ground for the gauges are actually at each of the sending units.  All three sending unit grounds would have to be bad.
Offline Mach1Rider
  • Active Poster
« Reply #5 on: August, 24, 2011, 08:28:53 AM »
I agree, the 14-15v while running may have cooked or overheats the CVR.
It may be using an old style CVR may keep this from happening.
If its already broken...I can't hurt it!
Offline Dne'
« Reply #6 on: August, 24, 2011, 09:04:07 AM »
I had installed a new electronic CVR.   I do have the old one around here somewhere.  I'm kind of worried about the alternator putting out too many volts (alt with external VR), but the volt meter in the car doesn't exceed 15 volts upon startup, then settles back down to 14 when running.
Offline Mach1Rider
  • Active Poster
« Reply #7 on: August, 25, 2011, 10:06:35 AM »
Yes,  Missing,loose,poor body grounds are the leading cause of electrical problems.
They are very important, Just take one look in a new cars engine bay and see just how
many they have in place to insure all the sensors work properly.
Offline apollard
« Reply #8 on: August, 25, 2011, 11:17:14 AM »
14 volts when running is fine. Modern cars typically run at 13.8-14.4 volts, and batteries like that much better. All auto electical components should be able to handle that. Remember that a fully charged "12 volt" battery is really 13.6 volts, so you are running just above that.
I think you have a bad ground or overheating CVR. When electronic voltage regulator components overheat, they are designed to reduce voltage output, and eventually shut off to protect themselves - and reset when they cool off. Exactly the behaviour you are seeing, so I think it is overheating. Pretty common with the cheaper electronic voltage regulators IME.
Offline Dne'
« Reply #9 on: August, 25, 2011, 01:38:49 PM »
Soooo, you think maybe putting in a non electronic may be the way to go? I haven't ordered anything yet.  I agree with you on it must be overheating as when I let the car rest for 20-30 minutes, it's starts working again!  Plus when I have it apart, I'll double check on the ground again. this wouldn't be something to keep me from driving the car? I wouldn't want a fire under my dash! thanks!!
dne'
Offline apollard
« Reply #10 on: August, 26, 2011, 07:20:17 AM »
dne'
Doubt it would cause a fire, they are pretty good at protecting themselves. If it did go, it would just let the smoke out and quit working (all electronics really work on smoke, when it gets out, the part stops working  :roll).
Knowing something about voltage regulators, a good quality electronic one will not be cheap. I'd put the original back in, or a mechanical replacement. Nothing wrong with them for the application IMO. Our guages don't need ripple free stabilized voltages, just something approximating 5-6 volts. Heck, our guages are pretty much indicators anyway, not exact instruments.
Offline Dne'
« Reply #11 on: August, 26, 2011, 03:16:51 PM »
Now if I can just find that old CVR! nah, I'll just order a new older style! just like to see the gauges at least move! ; )   Thank you!!
Offline TB350
  • Active Poster
« Reply #12 on: August, 28, 2011, 06:24:33 PM »
65 Fastback,302, 4spd, 4 wheel disks
 A/C, MSD, OTR uca and lca, roller perches and idler, SorT strut rods
