Hey Guys,I'm looking for advice on how to install new door glass in a 67 Mustang fb. Not so much installing the glass & window regulator into the door, but the window glass into the metal frame and stainless steel window trim. I purchased the correct thickness glass setting tape (15/64" for the lower frame and 1/4" for the stainless trim along the top), but I would like some tips on how to install the glass into the window frame.Should I use any lubricant (water, alcohol, silicone?) on the metal frame and glass setting tape?Should I heat up the glass setting tape to make it more pliable?What's the best way to "press" the glass into the window frame channel?Or should I just go to an experienced glass installer to get the job done right?... without breaking my new smoke glass.
First off, those glass setting tape thickness's are WAY off. As I remember there are up to three different thicknesses used to get a tight fit.... 1/64th, 1/32nd and 3/64ths if I remember correctly.I've done this a couple times and it's not difficult at all. The most difficult part of the whole operation is establishing which combination of tape thickness to use to secure the glass into the frames channel. A little bit of soapy water to help reduce friction while the frame is "tapped" (yes, but with a rubber mallet) onto the lower edge of the glass.Make sure the glass is properly positioned (fore and aft) on the channel before you start getting it into the channel.The outer band of stainless trim is much easier, but installed with the same methods.
just snug where a few light mallet blows sets the glass in place
how close is the fb to being assembled again?
