I've never mated a 460 and a C6 but I don't think it would be any different than a SB and C4. I usually would have the engine supported by the hoist resting on the floor and slide the tranny up to it. You absolutely sure they are compatible? Shaft length/bellhousing, spline, etc.? If you've got the converter fully seated I can't think of why you'd have a problem. How close are you to getting it?
I am just having lots of trouble with the alignment during the mating process.
Is there an issue with the guide pins?
They could be helping to aggravate the misalignment issue.
Dang...it is one pin in one hole......how hard is that?
Careful Pete. Give him enough crap and he'll lump you in with Bob and ole' what's his name.
did you make sure the converter fits the crank? mismatched years? I have a 70 429 and a 77 C6 and the pilot hole is smaller on the 70 engine so I needed the older converter. If you have a newer engine and older trans it will be sloppy but should go together. I don't recall what year they changed.Just letting you know if you don't already...
LoL.AND you still didn't answer the question though.
