Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Linux Mint 11 Rulez....
Home
Help
Login
Register
StangFix.com Forums
Forum
1964 1/2 through 1973 Mustang Boards
Heating / Cooling
CAA AC System
Random Image from the Gallery
Latest Victims
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: CAA AC System (Read 2106 times)
janschutz
Corn Hauler
Shutup Already
Allen, TX
Re: CAA AC System
Reply #25 on:
August, 08, 2011, 04:54:46 PM »
20" radiator with shroud and ac/clutch fan
Logged
John L. Anschutz
2 68 Coupes
AzPete
Classic...less
Global Moderator
Shutup Already
Re: CAA AC System
Reply #26 on:
August, 08, 2011, 04:59:27 PM »
When does it over heat.....low speed, idle, cruising?
Logged
USAF/Ret.
7 Previously owned..66-07
janschutz
Corn Hauler
Shutup Already
Allen, TX
Re: CAA AC System
Reply #27 on:
August, 08, 2011, 05:15:13 PM »
It overheated the day it was 110 here. Today, it was just 100 when I drove it and it did not overheat but was hotter than normal. It was in city driving (low speed).
Logged
AzPete
Classic...less
Global Moderator
Shutup Already
Re: CAA AC System
Reply #28 on:
August, 08, 2011, 05:19:05 PM »
Low speed over heating indicates not enough air flow thru the radiator. This is where the fan comes in at. You might try a stock 7 bladed (I think they are 7) fan. It will move more air for you at slower speeds. I have never cared for the clutch fans.......
Also, if the thermostat does not have a chance to close, you cannot cool the radiator. What temp thermostat are you running?
Logged
janschutz
Corn Hauler
Shutup Already
Allen, TX
Re: CAA AC System
Reply #29 on:
August, 08, 2011, 06:08:46 PM »
I think, a 185. Not sure, it has been a while since I put it in.
Logged
AzPete
Classic...less
Global Moderator
Shutup Already
Re: CAA AC System
Reply #30 on:
August, 08, 2011, 06:13:18 PM »
I would run a 195....that is what I had in all my older Mustangs. That keeps the coolant in the radiator longer so it can cool off more without hurting the operating range of the engine.
Logged
janschutz
Corn Hauler
Shutup Already
Allen, TX
Re: CAA AC System
Reply #31 on:
August, 08, 2011, 06:29:16 PM »
Thanks, I will try that first. It figures that I gave away a 7 blade fan a couple months ago. Now I might have to buy one.
Logged
AzPete
Classic...less
Global Moderator
Shutup Already
Re: CAA AC System
Reply #32 on:
August, 08, 2011, 06:32:17 PM »
Also, don't go to heavy on the coolant vs water. Water is the better cooling fluid, coolant does the lubing and anti corrosion jobs.
Logged
gwstang
Valued Member
Re: CAA AC System
Reply #33 on:
August, 12, 2011, 06:08:49 PM »
This is where I am glad that I put the 2 speed Taurus fan and aluminum radiator on the '66. With the fan controller, just hook the compressor wire to the place on the controller for it and the fan comes on when the ac is turned on. Works great and doesn't over head at low speeds because the fan is pulling when the ac is on. I stay cool and the stang stays cool. Nothing like a happy camper!
Logged
Timid men prefer the calm of despotism to the tempestuous sea of liberty. Thomas Jefferson
janschutz
Corn Hauler
Shutup Already
Allen, TX
Re: CAA AC System
Reply #34 on:
August, 17, 2011, 11:50:05 AM »
Put in a 190 degree thermostat and dove it in the 104 degree heat. I kept cool and the engine was better. Still room for improvement. I watching ebay for a fan now.
Logged
AzPete
Classic...less
Global Moderator
Shutup Already
Re: CAA AC System
Reply #35 on:
August, 17, 2011, 12:41:46 PM »
Good job.............I found buying direct from SPAL was the best deal at the time I was doing this.
Logged
gwstang
Valued Member
Re: CAA AC System
Reply #36 on:
August, 29, 2011, 05:02:45 PM »
Why do the compressor hoses exit the side and not on the top like mine are?
Logged
AzPete
Classic...less
Global Moderator
Shutup Already
Re: CAA AC System
Reply #37 on:
August, 29, 2011, 05:16:50 PM »
That depends on how the compressor is mounted. Mine on the '66 exited the side per the directions.
Logged
janschutz
Corn Hauler
Shutup Already
Allen, TX
Re: CAA AC System
Reply #38 on:
September, 25, 2011, 12:43:32 PM »
A couple weeks ago, the 20" radiator sprung a leak. I went ahead and got a 24" big block radiator and brackets along with a non clutch fan. It is cooler now but so is the temperature outside. I guess I will see next summer.
Julie wants it more quite now no I guess I need to research some sound deadner.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
StangFix.com Forums
Forum
Heating / Cooling
CAA AC System
Powered by
EzPortal
