Author Topic: Engine has to come out.  (Read 1883 times)
Offline jmbour66
  • 4 out of 5 people can't do fractions
  • Active Poster
Re: Engine has to come out.
« Reply #25 on: July, 14, 2011, 05:53:30 AM »
I had some Comp Cam Lifters and Cam Shaft fail as well, although mine were Hydraulic Flat Tappet.  I had to clean out three of my bores and make sure that the oil ports were not clogged from the failed lifters.
Offline 68EFIvert
« Reply #26 on: July, 14, 2011, 07:40:14 AM »
Are the lifter bores OK?
Lifter bores appear to be fine.  I will call them today and see what they have to say.
Darreld
Offline 68EFIvert
« Reply #27 on: July, 14, 2011, 08:54:24 AM »
I just got off the phone with Comp Cams and they want me to mail the lifters to them for inspection. If they were infact the cause of the problem then it looks like they will help me out. I am keeping my fingers crossed on that one. Since the pins seem to be coming out of multipe lifters they fear it may be a indication of a larger problem with many more lifters. They also wanted to see the cam but it is already on its way to Bullet.
Offline GTchris
  • Active Poster
« Reply #28 on: July, 14, 2011, 11:32:01 AM »
well on the bright side, it's not like you are missing a bunch of great cruising weather.
When is summer going to start here..
Offline 2ndgen
  • Loves the Sheep Organs
  • Active Poster
  • Waiting for parts...
« Reply #29 on: July, 18, 2011, 11:20:17 AM »
Just a thought...
As I recall, Jay liked to use a lot of lift and relatively short duration in many of his grinds... By chance did you check to see if the lifters were hitting/lifting your dog bones? I'd hate to see you go through this again...To check with hydraulics you must "convert" the lifter to a solid by stacking it with washers or inverting the plunger to simulate a fully pumped up lifter. Don't forget to check both intake and exhaust lobes.
Good luck,
-Rory
"I'm not a Mustang expert, but I play one on the VMF StangFix"
69 Mach 1 - 393W - AOD w/4R70W internals - 3500 stall - 3.70 tru-trac - PS w/o air
multi-year rotisserie restoration
It now drives!
Offline 68EFIvert
« Reply #30 on: July, 18, 2011, 11:30:02 AM »
After the destruction I did look at the lift of the cam and if it would allow the lifter to go below the dog bone and it did not.  It was very close to flush with the top of the dog bone but not below.
I am feeling that this problem was likely caused by the pin on the lifter that secures the roller came out.  The engine ran crappy for a short period of time before it made the noise.  I think that is the time where the roller came loos but was wedged in the lifter.  Eventually it came loose and then started to grind and turn the lifter sideways causing the dog bone to break.  This is pure speculation on my part at this time but with 5 other lifters about to loose their pins it carry's more weight in my mind at this time.
I'll give comp cams another day or so to investigate the problem before calling them.  On Wednesday Bullet Cams should get the camshaft I mailed last week.  I am keeping my fingers crossed they can regrind it.  The would save me over $250.
Offline 2ndgen
  • Active Poster
« Reply #31 on: July, 18, 2011, 12:16:19 PM »
I think you misunderstand... I am curious if your lifters went too high, not too low. Hopefully this was a roller pin issue, but what I was concerned with was if your dog bones were staying flush with the block, or if at maximum lift the lifters were hitting the bottom of the dog bones.
Good luck and post the final outcome!
-Rory
Offline 68EFIvert
« Reply #32 on: July, 18, 2011, 12:24:26 PM »
Sorry, I did misunderstand.  I check that with Com Cams when i was on the phone.  My cam had .569/.561 lift and according to the Comp Cams guy the lifters can take over .600 lift.
Offline 68EFIvert
« Reply #33 on: July, 24, 2011, 06:19:53 PM »
I spoke with Comp Cams on Friday and they told me that it was a dog bone failure not a lifter failure.  Not sure I really agree with the decision but they are going to give me credit for 1/2 the cost of the lifters I can use some other time.  I would use it now but I already have new lifters.  I also got good news from the cam grinder.  They will be able to regrind my cam which will save me about $300.
I hope to get the cam late this week and get the car running shortly after that.  Come to think of it I will have to go on a vacation, wire my low voltage for the new house and other crap before I can get to the Mustang.  Life is too damn busy.
Offline 68EFIvert
« Reply #34 on: September, 05, 2011, 01:01:55 PM »
Well I finally got the engine back in the car. I had a difficult time starting her at first because I had it 180* off on the distributor. Once I corrected that she started right up. I timed her and let her get up to about 150 degrees before turning the car off. She ran smooth and well. No oil leaks or water leaks so I partially drained the radiator of the water and added almost a gallon of antifreeze.
My next step was to take her out for a spin and make sure there wasn't any problems before I put the hood back on. When I wen't out to go for a drive she was difficult to start and then died. 20 minutes earlier she purred like a kitten. WTF. Now the car won't start. I think I am back to my original problem. Ran well then won't start for any apparent reason.
I am disgusted right now. Almost $2000 to repair the failed lifter damage, a summer without driving the car and then back to square one.
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #35 on: September, 05, 2011, 01:27:08 PM »
I'm sure you have checked the basics, spark..., fuel..., maybe compression test?
Offline 68EFIvert
« Reply #36 on: September, 05, 2011, 01:52:23 PM »
I have check those items except compression check.  I went back out a few minutes ago and the car started right up.  Drove it to get some gas and it started up again there.  I am really confused now.  I hope the problem just goes away (wishful thinking) and I can drive it a little more before summer is gone and the rains come back to the Pacific NW.
On a side note our 2001 Lexus IS300 started to make noise on the top of the engine on saturday morning.  It will go to the shop tomorrow.  I am not looking forward to that bill.  We have owned the car since new and it has about 106,000 miles on it.  Never a problem except to replace a battery.  I can't be too upset about that I guess.  Still better than a car payment.
I will go down to pick up a rental car this evening to get me buy for the next few days.  I originally thought my Mustang would be up and running so I would drive it.  Now that I am not sure if it will be dependable I am scared to drive it anywhere I could be stranded.
Offline DougG69
  • Cleveland Powered
« Reply #37 on: September, 05, 2011, 02:00:04 PM »
Sorry to hear you are having such rotten luck with the car.
I'm no mechanic, and don't feel qualified to give such advice over the internet, but I'd like to ask a few questions. Maybe the answers would be helpful to someone with more experience...
What did you end up setting your initial timing to?
How long was it between the time you shut the car off & attempting to re-start?
If you allow the car to cool off completely, will it then start?
[edit: I see that it did from your last post]
« Last Edit: September, 05, 2011, 02:01:36 PM by DougG69 »
-Doug-
69 Mach 1 - 351c, TKO
Offline 68EFIvert
« Reply #38 on: September, 05, 2011, 03:32:15 PM »
I set the timint to 10*, basically the same spot the tuner used.  The car sat for about 7-10 minutes at the gas station before I started it again.  the first time it sat for about 20 minutes.  I went out and started it 2 more times since the trip to the gas station and it starts just fine.  Well almost fine.
I installed a small high torque started and cheated on the wiring.  I installed the battery cable from the S terminal like my old starter to the solonoid on the starter and a small jumper from the other post on the solonoid to the same terminal the starter cable goes to.  the starter works fine but stays engaged for about 1/2 second after the engine starts up.  I will have to rewire that to the suggested wiring diagram from the starter company.
Offline 67 Fastback
  • On 70_Fastback's "Shart" List...
  • Bill Watson
    • 67 Mustang Fastback Restoration
« Reply #39 on: September, 05, 2011, 04:26:21 PM »
Dang, hate to hear your troubles. I was wondering how things turned out.
Bill
LIVING THE DREAM OR RUNNING IT DOWN... HAVEN'T FIGURE OUT WHICH YET
Offline Mustang Mike
    • My 68 from start to almost finished
« Reply #40 on: November, 06, 2011, 09:00:56 PM »
Sorry to hear of your problems. Hopefully all is well now. I smoked my 347 this last summer. Broke the block in half and melted all the pistons. Needless to say I sold my supercharger. I was tired of melting pistons. I did throw a nice 351 together using most of my old components. She runs like a scalded dog still but not as strong as the 347.
Mike W.
Offline 68EFIvert
« Reply #41 on: November, 07, 2011, 08:10:38 AM »
I did rewire the starter and it works.  I did have a problem where the started stopped working and I let it sit for a while and then it started just fine.   :shrug  I do have a pretty bad oil leak now though.  It looks like my pistons haven't fully seated and is causing excess blowby (crank case pressure).  I installed an electric vacuum pump last year to help with this problem but the pressure is building before it even gets to boost.  I will try to add another PCV and if that doesn't do anything I will add a belt driven vacuum pump and see what happens.  When I have that done I will take it back to the tuner to have him touch up tha car again.  I am having some issues where the car wants to die when I push in the clutch and coast to a stop.
I haven't had time to look at it and won't likely be able to for a few more weeks.  We are about to move in a new house and that will occupy most of my time.  Another distraction is I picked up my new project, 1968 Volvo P1800.  I have some V* power in mind for that project. :yah  And no that car will not have a blower or turbos.  Just a mild mannered 450-500 hp LS chevy.
Offline 95GTSpeedDemon
  • Found it!
« Reply #42 on: April, 02, 2012, 07:33:27 PM »
This is my first post here. I stumbled upon this via google.
This is da-ja-vue for me.
CI HYD roller, 226/246 .603/.590, comp 851 lifters shimmed. 1/8th preload as per jay. power died at 6400.
driving home from work and the car just died on me. towed it home.
Long story short, lifter broke at the same place as yours, where the body hold the roller. it broke, the lobe jammed up against lifter and sheared the cam pin AND bolt. the threads were still loc-tited in the cam. 4 more lifters with the pins coming out.
I sent comp all the parts. They said it was their lobes. All my parts were over a year also, as it sat for awhile.
Literally comp said the cam failed and caused the lifters to fail. i shit you not, i recorded the conversation.
Comp gave me a half credit on the lifters and cam. i found a rough spot in the ultra gold rockers, which have a lifetime warranty fyi, so replaced them.
i got lobes 3192/3113. 224/242 .605/.587 XE HYD lobes, closest they had.
Then i bought the 838 solid rollers. lashed them at .008 hot.
So far so good. it keeps the power past 7k now, but i cant spin it that high.
Offline 68EFIvert
« Reply #43 on: April, 03, 2012, 07:42:19 AM »
That sucks.  I spoke to my tuner last week and he said they recently had the same problem.  Comp Cams told them that they had a batch of bad lifters and replaced his stuff.  Of course it was less than a year old.  They have since done a redesign of the lifters.  I did not want to give the dog bone lifters another shot at killing my engine so I went with Tie bar lifters this time around.  Cross my fingers.
  • Found it!
« Reply #44 on: April, 06, 2012, 04:03:38 PM »
I figured they had a bad batch, they just wouldnt admit it to me. that would have given me leverage.
