Author Topic: Car won't start need help UPDATE help me pick a starter  (Read 783 times)
Offline pnandy
« on: June, 17, 2011, 06:52:21 PM »
Ok so it's not the battery think it's the starter I wasn't at home so I tried to push start it I had a hill to go down but it wouldn't work it the wheels wouldn't turn after I let the clutch out any ideas??
« Last Edit: June, 19, 2011, 03:16:18 PM by pnandy »
Patrick
Offline AzPete
  • Classic...less
Re: Car won't start need help
« Reply #1 on: June, 17, 2011, 07:01:09 PM »
Can you turn the engine by hand? Letting the clutch out while rolling should have turned the engine. If it did, then your issue is in fuel or spark.
USAF/Ret.
7 Previously owned..66-07
Offline Jonk67
  • Yak, Yak, Yak
  • Smyrna, TN
« Reply #2 on: June, 17, 2011, 07:01:36 PM »
Ok, you lost me at you were on a hill but the wheels wouldn't turn when you let the clutch out?
First you get rolling  ~3,5,10mph something rolling but not fast, normally a couple guys can push it fast enough on a flat road. Put the key at the on or 'run' position (where the key is while you're driving), then you let the clutch out in 2nd and it spins the motor, then push the clutch back in and the motor should be running.
Jon
Offline pnandy
« Reply #3 on: June, 17, 2011, 07:33:33 PM »
Motor wouldn't spin when going down hill key was on I done it many times before in other cars
Offline pnandy
« Reply #4 on: June, 17, 2011, 07:49:49 PM »
The wheels didn't spin after the clutch was let out they slid and would have stopes the car if I did t put the clutch bck in
Offline Jonk67
  • Yak, Yak, Yak
  • Smyrna, TN
« Reply #5 on: June, 17, 2011, 08:37:36 PM »
Ok, back to Pete's question, can you turn the engine by hand with a ratchet on the crank bolt?
Jon
Offline crustycurmudgeon
  • Mr. California Black Plate
« Reply #6 on: June, 17, 2011, 08:42:03 PM »
Agreed, sounds like something locked up.
Frank
Offline B67FSTB
  • President, StangFix Belgium
« Reply #7 on: June, 17, 2011, 10:52:40 PM »
Transmission failure ??   Did you have some problems earlier on with your transmission ??? :confu
Bruno
Offline nymustang
« Reply #8 on: June, 18, 2011, 04:50:06 AM »
When you try starting it with the key does anything happen at all? Is the starter trying? No noises? Have you tried spinning it by hand yet?
« Last Edit: June, 18, 2011, 04:54:37 AM by nymustang »
Carl
Offline cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« Reply #9 on: June, 18, 2011, 05:43:08 AM »
Can't see how it would be the tranny if you push the clutch in (assuming you can) and turn the key over.  Sounds like the motor to me.  Is the Starter stuck against the flywheel?
We need a Saturday lunchtime update  :rant
Online Mach1Rider
  • Active Poster
« Reply #10 on: June, 18, 2011, 05:51:04 AM »
I suggest pulling the plugs out and try turning it over.
My bet is that one or more cyl's has hydo locked for some reason.
If its already broken...I can't hurt it!
Offline B67FSTB
« Reply #11 on: June, 18, 2011, 08:22:31 AM »
Yeh  , you're right Craig.Sorry , my mistake.Didn't read it very well.
As suggested , try to rotate the crankshaft by a wrench at the crankshaft damper bolt.Clockwise of course.
Offline pnandy
« Reply #12 on: June, 18, 2011, 12:21:27 PM »
I believe that is what's wrong planning to replace the starter next weekend if I have time...no time this weekend :-/
Ok so next question what starter should I get?
And it's lunch time in so cal now
Offline Sluggo
  • How you like dat Jake?
    • www.StangFix.com
« Reply #13 on: June, 18, 2011, 08:11:50 PM »
Can't go wrong with a mini starter.
Offline B67FSTB
« Reply #14 on: June, 19, 2011, 02:26:41 AM »
+1 here
and look out that there is a differents if you have auto or manu trans.
Offline cmayna
  • DILLIGARA ?
« Reply #15 on: June, 19, 2011, 05:08:21 AM »
Look up:  NAPA mini starter #4N-9240 which is what I'm using in Shag.
Offline pnandy
« Reply #16 on: June, 19, 2011, 02:59:23 PM »
Craig will this fit my application? 347 4speed any issues to know ahead of time before the install should I buy any else for the install??
Offline gotstang
Re: Car won't start need help UPDATE help me pick a starter
« Reply #17 on: June, 19, 2011, 03:38:48 PM »
http://www.dbelectrical.com/p-1322-new-ford-mini-pmgr-starter-302-351-manual-transmissions-3223-sfd0012.aspx
These are the same as the OEM Ford ministarters from teh 1990s and the same as the $175 Ford Racing ministarter. They seem to be very well made too, despite how CHEAP the price is.  :peter
Start a Coupe coup!
'66 Coupe 289 & 3 speed 5.0-AOD, here we come!
My Webpage & Tech pages
Offline Sluggo
    • www.StangFix.com
« Reply #18 on: June, 19, 2011, 07:28:01 PM »
Agreed. Exact starter I'm running. No issues whatsoever. Spins the stroker over and starts at a bump of the key hot, cold, hot soaked, etc.
Offline pnandy
« Reply #19 on: June, 20, 2011, 10:36:29 AM »
Ok sounds good ima buy the db starter any issues with the install I should know of ahead of time should I be buying anything else?
Offline Sluggo
    • www.StangFix.com
« Reply #20 on: June, 20, 2011, 06:09:47 PM »
Yeah, do not run the large wire to the starter from the same side of the solenoid it's on now. Run it from the battery side and the small wire from the starter side.
The starter motor needs to have power on it all the time. If you run them both to the starter side it will act stupid.
Offline pnandy
« Reply #21 on: June, 20, 2011, 06:53:57 PM »
Has anyone made an install guide for this don't wanna mess anything up :steer
Offline cmayna
  • DILLIGARA ?
« Last Edit: June, 21, 2011, 04:49:42 AM by cmayna »
Offline pnandy
« Reply #24 on: June, 21, 2011, 11:04:31 AM »
Thanks guys
