Linux Mint 11 Rulez....
Have a chat with Jeremy. He helped me put together my lighting plan. 21 2 x 4' T8 Fixtures (42 bulbs total). There is so much light I rarely need a drop light when working UNDER the car. I love it. Put them on 3 switches so I don't have to have them all on if not needed.
I have 32 8' T12's, all 75 watts in a 32x30' garage. Us blue-hairs need more light...
The garage will be 31'x43' and the ceiling will be a smidge over 12'. A 2 post lift is in the plan. Maybe not right away but should be in there within the first year.
I have 2 240 volt outlet planned already and outlets every 6 feet in the construction area.
Not really current photos, but then again not much has changed.Built as attachment to house in 2001 replacing a single carport.Now houses 7 stangs. One or two must be moved out whenever a project is going on.Measures 24 ft. wide, 45 ft deep. Has 24 ft x 18 ft. loft.Highest ceiling is 22 ft.We live on a corner so has a double wide door in front and a single 16ft high door on the side.Big cathedral windows on both ends, four sky lights provide a lot of illumination.Heated with a 75,000 BTU Hot Dawg.J.
not much but its all i have
