Author Topic: EFI Ignition problem. Please HELP!!!  (Read 880 times)
Offline 68EFIvert
« on: June, 06, 2011, 06:33:28 PM »
I have been having problems with the batteries in my car lately.  I replaced a 6/7 year old Optima battery 2 months ago with a new red top optima.  That battery was dead after the car sat in the month for 2 months and I did not even drive it.  I thought it was just the new Mexican made Optimas.  The auto parts store tried to talk me out of getting it becasue they have been having problems with them.  Fast forward to Saturday when i exhcange the new Optima for an Orbital battery.
I did not have time to drive the car on Saturday so Sunday was going to be the day.  I pulled the car out of the garage and it ran like crap.  Sputtering, smoked like hell and the engine light came on.  WTF.  I drove it from a house we were moving it from last week after I jumped the 2nd optima battery.  It ran fine.  Now I change the battery and it runs like crap?
My code reader is burried in a box until the new house is built so I go the the parts store and buy another reader tonight.  Go to turn on the car and the battery is dead.  I am now thinking that my problem is much deeper than my battery.  I plug in my charger and hear some clicks in the engine compartment.  Since my battery is located in the trunk I asked my wife to come out and plug the charger in while I look for a short or something.
When she plugged it back it the coil was making some clicking sounds and I could see some sparks inside of it.  The distributor cap seemed to be clicking as well.  Could a bad MSD coil cause these problems?  I assume when the MSD box goes out there would not be any spark.  The rest of the ignition system is and MSD BTM box, MSD 6AL box, MSD distrutor, MSD TFI coil and new alternator.  The oldest part of the system is the coil, MSD 6AL and BTM boxes.  They have about 2000 miles on them.  Thanks for the help!!!!
Needless to say I did not hook up the code reader since the car doesn't have enough juice to turn the lights on.
Darreld
Online Sluggo
  • How you like dat Jake?
    • www.StangFix.com
Re: EFI Ignition problem. Please HELP!!!
« Reply #1 on: June, 06, 2011, 06:51:56 PM »
Was the key on or off when the clicking was going on?
The 6AL is supposed to be powered by a key on source as I remember.
Online Sluggo
    • www.StangFix.com
« Reply #2 on: June, 06, 2011, 06:55:11 PM »
Reading MSD instructions now.....
Found this tidbit.
Initial Spark: It is normal, yet not very common, for the MSD to produce a spark when the ignition
key is turned On. This is due to the capacitor being charged and if the pickup is in the right position,
it could trigger the ignition momentarily. This could also occur when installing the positive battery
cable
Offline 68EFIvert
« Reply #3 on: June, 06, 2011, 07:04:44 PM »
The key wasn't even in the ignition at that point.
Offline buening
« Reply #4 on: June, 06, 2011, 07:15:25 PM »
Regarding the batteries, have you gone through the process of removing the fuses one at a time and measuring draw on the battery to determine if you have a slow drain from something?
Custom Motor Mounts
T56 Conversion
Online Sluggo
    • www.StangFix.com
« Reply #5 on: June, 06, 2011, 07:23:32 PM »
Two power leads and a heavy red go straight to the battery.
Heavy red carries this note.
Note: Never connect the alternator
I did not look for an internal diagram of the box but I'm gonna guess the two power leads go to the capacitors inside the box. If the capacitors have shorted to ground I'm sure they could drain the battery in a hurry.
Try disconnecting the two power leads and see if the battery dies with them disconnected. if it still dies disconnect the heavy red and see if that fixes it. If not reconnect those wires and disconnect the switched wire from the ignition. If that fixes it, I'd look at the possibility that the ignition switch is not turning off properly.
Of course you'll have to charge the battery between checks if it's dead.
Online Sluggo
    • www.StangFix.com
« Reply #6 on: June, 06, 2011, 07:26:50 PM »
BTW, Rick had a similar problem recently and last I heard the alternator was the problem. He was running a 1 wire IIRC.
Offline 68EFIvert
« Reply #7 on: June, 06, 2011, 08:05:43 PM »
Thanks for the help guys.  I am charging the battery with it disconnected.  I have already unplugged the two small red wires.  Once the battery is charged and holding the charge I will connect it to the car.  If it starts draining right away I will know that may be the problem.  If it holds it I will disconnect the large red wire like you suggested.
I haven't had a chace to check for other draws.  Quite honestly I wasn't sure where to begin.  Electricl stuff is like the great unknown for me.  I am much better than I used to be but not confident at all when it comes to electrical problems.
My battery was just put on the car this winter.  That doesn't mean much I guess.  it is a Tuff Stuff chrome alternator that puts out 150 or 200 amps IIRC.  Thanks for the help in giving me a direction to look for the problem.
Offline 68EFIvert
« Reply #8 on: June, 06, 2011, 09:23:27 PM »
I charged the battery and it holds a charge when disconnected.  I unplugged the 2 small wires on the MSD box then connected the battery.  The battery dropped rapidly.  The large red wire is much harder to reach.  I have to pull the blower inlet and MAF meter to reach it.  Good project for tomorrow night.
Offline 68EFIvert
« Reply #9 on: June, 06, 2011, 09:30:05 PM »
The switch idea may make sense.  I took apart the dash for paint over the winter and started having the problems after that.  I know it turns off to a certain point because the fuel pump primes when I turn the key on.
I thought about replacing it but decided to save the time of ordering one.  I may need to go back and do it later.
Offline 68EFIvert
« Reply #10 on: June, 07, 2011, 08:47:09 PM »
Progress report.  I started pulling fuses before taking apart the MSD box any further.  I found that when I pulled the fuse that runs the courtesy lights the drain on the battery stops.  This makes sense since this winter I repainted the dash and fixed what I thought was a short in my passenger side courtesy light.  A PO had twisted loose wires together to operate the light.  I reconnected it using connectors and put a new fuse in.  The lights seemed to operate just fine.  Is it possible to connect the lights the wrong way? + on - and - on +?
What other items work off the courtesy light fuse.  My wiring book is packed away in a box.  Thanks guys!
Offline Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
« Reply #11 on: June, 08, 2011, 02:18:41 AM »
On a 68, the following items work off of the courtesy light fuses: courtesy lights, glove box light, map lights, clock light.
Panama City, FL
Offline buening
« Reply #12 on: June, 08, 2011, 04:14:10 AM »
If you have a clock it will obviously cause a little bit of battery drain (assuming it works!), but how much of a drain this I do not know.
Offline 68EFIvert
« Reply #13 on: June, 08, 2011, 06:31:15 AM »
So if I live without interior light the car will run correctly.  What would cause the battery to loose 1 volt in a priod of 15 sceonds.  Could a short do that?  Wouldn't the fuse blow before it would do that?  Sorry for all the questions.
Offline 6t6red
« Reply #14 on: June, 08, 2011, 07:19:35 AM »
You mentioned that you had to fix a connection for the pass. side courtesy light.  You may want to pull the door switches and make sure one of the connections isn't touching the metal where they go thru the door frame area.  Just another thought of a possible shorting area for that circuit.
  Paul
Offline Midlife
  • DOM
« Reply #15 on: June, 08, 2011, 08:24:21 AM »
The system is fused with a 20Amp fuse (presuming it is the correct fuse).  A short would cause the fuse the blow.  A severe battery draw-down indicates a weak battery as well.
Offline AzPete
  • Classic...less
« Reply #16 on: June, 08, 2011, 09:26:58 AM »
By chance, was the door open when testing for battery drain?
USAF/Ret.
7 Previously owned..66-07
Offline 68EFIvert
« Reply #17 on: June, 08, 2011, 11:47:29 AM »
The battery drain is there when the door is open or closed.  It doesn't seem to matter.  Does the ignition switch have anything to do with that circuit?  How about the headlight switch?  IIRC if you turn the headlight switch you can turn on the interior lights.   :shrug
Offline AzPete
  • Classic...less
« Reply #18 on: June, 08, 2011, 01:33:28 PM »
Nothing to do with the ign. switch. The headlight switch ...... you are correct. There is a small lobe felt as you turn the knob. It also controls the brightness of the dash lights.
Do the interior lights shut off when the door is closed?
Offline 68EFIvert
« Reply #19 on: June, 08, 2011, 02:41:03 PM »
The lights do turn off.  The other thing I was thinking about is the horn.  I am using a GM wiring harness and Flaming River column.  Since the horn is a constant hot item like the courtesy lights I wonder if it could be on the same circuit.  I had the steering wheel off this winter for repaint and wonder if the wiring could be the issue there.
I was speaking to a buddy today about this and he suggested hooking up the charger to the car and feeling for a warm wire.  Once I found the warm wire he was convinced I would find a parasitic ground that is not enough to pop a 20 amp fuse but could draw down the battery pretty quickly.
Offline AzPete
  • Classic...less
« Reply #20 on: June, 08, 2011, 03:10:44 PM »
....or just wait for the smoke......
If it stopped when you pulled the interior light fuse, it pretty much has to be there. Get a schematic and start checking all connections vs wire colors.
Not the best but it works... http://hammar.dyndns.org/~djhamma/wiring/1968/E8.jpg
« Last Edit: June, 08, 2011, 03:13:58 PM by AzPete »
Offline 68EFIvert
« Reply #21 on: June, 08, 2011, 04:26:55 PM »
I started the car today with a fully charged battery and she ran dine.  As stated earlier the volts must have been low enough to cause injector problems.
Tonight I will unplug the steering column harness and see what happens.  I have determined that both the horn and flashers are on the  courtesy light circuit.
Offline Midlife
  • DOM
« Reply #22 on: June, 08, 2011, 04:40:38 PM »
The flashers may well be on the courtesy light circuit, but the horn signal comes from the headlamp switch.  Now then, given that you have a GM wiring harness, all bets are off with what should be on that light circuit.
Isn't GM a PO?
Offline AzPete
  • Classic...less
« Reply #23 on: June, 08, 2011, 04:44:31 PM »
Isn't GM a PO?
Ahhhhh....I forgot that little detail.....
Offline 68EFIvert
« Reply #24 on: June, 08, 2011, 06:08:11 PM »
I firged out the problem.  When I put the bulb back in the courtesy light it came loose a little bit from the housing that holds it to the dash.  I was just enough to cause the short.  Everything works well now.  Well everything but the flashers but that is another topic.  I guess that mean I can't break down on the side of the road.   :thu  What a wild goose chase this electrical gremlins can be.  Now I know why it confuses me..... :confu
Thanks for all the help guys!!!!  Now maybe I can go get a sound clip of the car.  One with the mufflers and one with the cutouts.   :thu
