Author Topic: Replace or just patch it?  (Read 1387 times)
Offline slingslingbinks
  • NewB
Re: Replace or just patch it?
« Reply #25 on: May, 20, 2011, 05:25:47 PM »
I said heck with it, and just going to replace the whole thing. I have a brand new whole apron, so might as well use it all.  :thu
That's what i would do. Sence your gonna replace the apron, Take a 1/4 inch thick cut off wheel and chuck it into a die grinder and grind down your spot welds from the apron side. That way you don't cut a hole on the rad. support or the shock tower. My rad. support was previously replace'd and there's a ton of holes in the apron's where they drilled all the way through. Any thing u wanna keep hole-less, grind down the spot weld and pop it loose with a gasket scrapper. C-ya Scott
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
« Reply #26 on: May, 22, 2011, 09:06:53 AM »
...and I have yet to find a replacement.
What bellhousing Mid?  I have a couple extras here.  Maybe I can help you out.
Offline Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
« Reply #27 on: May, 22, 2011, 01:16:59 PM »
I'm in need of a 6 bolt 289/302 manual bell housing.  C5DA-6394-A.  The one I have in the car has two threads blown out that accept the tranny, and the PO over-drilled the holes and tapped them for metric bolts.
Everyone says they're a dime-a-dozen, but every swap meet I attend, I can only find the 5 bolt versions or truck versions from the 80's.
Panama City, FL
Online cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« Reply #28 on: May, 22, 2011, 02:50:43 PM »
If my local mustang salvage yard has one interested in buying it?
Offline Midlife
  • DOM
« Reply #29 on: May, 22, 2011, 04:41:21 PM »
Sure.  I'll PM you what I think one is worth.
Offline 70_Fastback
« Reply #30 on: May, 22, 2011, 05:06:35 PM »
Sorry Mid, mine are all C4 automatic B.H.'s.
Offline jims6t6
  • Knoxville, TN
« Reply #31 on: May, 23, 2011, 03:52:59 AM »
Hope it's more then a dime. :roll
Online cmayna
  • DILLIGARA ?
« Reply #32 on: May, 23, 2011, 06:05:15 AM »
Back to Kats original program.  Kat, keep in mind that you will lose your vin number unless you do a vin graft (chopping out the vin number and welding in into place on the new apron).  Not saying this is legal or not and since the vin number would be hidden by the fender, why bother?
Offline Kats66Pny
« Reply #33 on: May, 23, 2011, 06:35:42 AM »
Quote
Um there is no VIN number on the battery apron.  :shrug   I just double checked. The other 3 aprons though have VIN on them that all matches.
« Last Edit: May, 23, 2011, 06:39:07 AM by Kats66Pny »
Online cmayna
  • DILLIGARA ?
« Reply #34 on: May, 23, 2011, 08:08:52 AM »
Hmmmm, I just realized that maybe the 65 doesn't have it on the battery apron afterall.  Red only has one on the drivers front apron.  My 68 has one on the battery apron.  Oh well.....
Offline abrahamfh
  • Photophiliac.
  • keeping it old school
« Reply #35 on: May, 23, 2011, 09:24:52 AM »
No worries there Kat. 65's, actually, I don't want to speak for all 65's but Fred's front clip metal was all original and the VIN was not stamped on the RS front apron. You will loose the date stamp on the RS front apron as I have. VIN was stamped though on the LS front back and RS back apron.
              MEET FRED!
Offline Kats66Pny
« Reply #36 on: May, 31, 2011, 07:29:24 AM »
I just want to say that grinding down welds sucks more than removing spot welds.
That is all. Have a nice day!  :Katcof
Offline 70_Fastback
« Reply #37 on: May, 31, 2011, 07:31:09 AM »
Not with the right tools/discs.
 :nut
Offline Kats66Pny
« Reply #38 on: May, 31, 2011, 07:37:56 AM »
I have an angle grinder and a sandpaper flap disc thingy. But since my left wrist is still hurting, it's a slow process! That and the disc needs replaced.  :roll
Offline Kats66Pny
« Reply #39 on: May, 31, 2011, 08:27:27 AM »
:shrug
Grinded the welds down as best as I could, covered the bare metal with self etching primer.
Offline silverblueBP
    • My 66 2+2
« Reply #40 on: May, 31, 2011, 08:38:38 AM »
Kat, you need to take close up shots of the ground welds and submit them to Professor Barrett for grading.
-Mark-
CarDomain
Offline 70_Fastback
« Reply #41 on: May, 31, 2011, 08:39:56 AM »
Looks good from my butt cushion!
