Author Topic: How do I get these off of the steering column...? (pics)  (Read 567 times)
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
« on: March, 09, 2009, 01:45:52 PM »
How do I remove those?  Do I have to remove the ignition switch first?  If so, how do I do that?
Online Fast68back
Re: How do I get these off of the steering column...? (pics)
« Reply #1 on: March, 09, 2009, 02:01:34 PM »
a BFH? I was already to tell you until I saw the ignition switch is in the column..... I know how to get it out of a '95 F150, but I doubt they are the same. Is there a small hole in the underside of the ignistion? On the F150 you have to turn the key to Acc then insert a pick into the hole, the ignition will then slide out (but make sure the wheel is not in the "lock" position)
Offline 70_Fastback
« Reply #2 on: March, 09, 2009, 06:58:46 PM »
I did see a tiny little hole in the lower side, basically behind the where the turn signal switch goes with a little plunger.  I tried pushing it but it didn't move.  But that was in the "locked" position.  I shall try other positions.
Online Fast68back
« Reply #3 on: March, 09, 2009, 07:19:12 PM »
J, I found this one on the web, its says RUN position
http://www.1969stang.com/mustang/forum/showthread.php?p=17287
Offline daveSanborn
« Reply #4 on: March, 09, 2009, 07:38:35 PM »
Why do you want to remove just those pieces?
Offline 70_Fastback
« Reply #5 on: March, 10, 2009, 04:31:24 AM »
To refinish them.  It will be a better job if they are out of the car.  And to me that is a pretty noticeable area.
Offline daveSanborn
« Reply #6 on: March, 10, 2009, 11:53:28 AM »
Quote
It will be a better job if they are out of the car.....
It'll be an even better job if you remove the whole column from the car.....
Offline 70_Fastback
« Reply #7 on: March, 10, 2009, 12:06:40 PM »
That's what someone else suggested on the other site.  I will probably persue that path.
Offline daveSanborn
« Reply #8 on: March, 10, 2009, 12:20:54 PM »
I figured that was what you were trying to do with your original inquiry.  Instead of removing just those pieces, remove the whole column... easy enough job.... and then either tape off or remove the ignition cylinder and repaint the whole column.  It'll come out much nicer.
Hint....
While the steering column is out, investigate ways to possibly shorten the length of the column/shaft.  Not by much, but an inch or two will be barely noticeable.  The extra room this creates for larger framed drivers is worth all of the trouble.
Offline 70_Fastback
« Reply #9 on: March, 10, 2009, 12:29:44 PM »
Thanks Dave.  And could you give me a brief synopsis of "how to" remove the column...? On the other site, one person said something about removing the 2 screws from the bottom and the clamp and just slide the column out over the shaft...?  Is that what you are referring to as well ?
Online Fast68back
« Reply #10 on: March, 10, 2009, 01:44:08 PM »
Lookin at your pic, looks like its got about 8 bolting it to the Dash, then a couple at the firewall, disconnect rag joint and slide 'er out.
Offline Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
« Reply #11 on: March, 10, 2009, 01:51:35 PM »
Hint....
Ummm...doesn't shortening the column/shaft place the steering wheel closer to the floor, and thus decreasing the leg/thigh to wheel distance?  I think you want to increase the length, not decrease it.
Panama City, FL
Offline 70_Fastback
« Reply #12 on: March, 10, 2009, 01:53:03 PM »
So if I understand what you are saying...  You're stating that you wish you had a longer shaft - correct?  :hmm
Offline AzPete
  • Classic...less
« Reply #13 on: March, 10, 2009, 02:02:54 PM »
How suddenly things get turned around........... :rofl
USAF/Ret.
7 Previously owned..66-07
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #14 on: March, 10, 2009, 03:11:24 PM »
I don't know about the ignition switch but if those parts are anything like the 67, this link might help.
http://www.stangfix.com/testforum/index.php?topic=1207.msg10167#new
Offline daveSanborn
« Reply #15 on: March, 10, 2009, 03:37:03 PM »
Quote
At some point, yes, you're exactly right.  If you move the steering wheel too far forward it will start to hit your knees.  The trick is to move it forward just a little bit.... an inch or so.
Online Fast68back
« Reply #16 on: March, 10, 2009, 05:58:44 PM »
If the column is bolted to the uderside of the dash, how would shortening it move it closer to the floor? It would be closer to the dash (or further from the gut is what I assumed Dave meant).
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #17 on: March, 10, 2009, 06:02:00 PM »
it will be closer to the dash but the colomn is at an angle so it will get lower too.
Offline AzPete
  • Classic...less
« Reply #18 on: March, 10, 2009, 06:02:56 PM »
It moves it closer to the pedal area of the floor. Since the column is at an angle, it will also be closer to the floor (straight down) as it moves closer to the dash.
