are those rubber plugs or holes in the fins for?
That looks like an aftermarket aluminum radiator to me.
Well I wouldn't touch it but I might suggest passing it on like so much has been passed on to you.
Am I seeing something different in Kat's pics? That looks like an aftermarket aluminum radiator to me.
Doesn't leak. Nothing wrong with it. I'm just replacing it with one similar to this, that fits a 5.0 swap that has the in/outs on both sides, not just the one.
Radiator shop can make that happen to your old one...
If you kept it, would you reuse the oil cooler mounts?
They can?? I really don't like how it was set up before and the bendy hose at the bottom (the green line), which is why I was going to just buy a new radiator.
That sounds like more work doing a swap.... or having a radiator shop fix the bottom hole. I'm just going to buy a new one so I have a nice new shiny one and call it done.
I assume you were not responding to me for I basically agreed with what you were planning to do.
