Author Topic: 10" x 2" drums in place of 10" x 1-3/4"?  (Read 315 times)
Offline dm289
  • Quiet Type
« on: May, 06, 2011, 04:38:40 AM »
Is there anything special required to put 10" x 2" rear shoes and drums from a 1967 up mustang in place of 10" x 1-3/4" shoes and drums on a 66 8 inch??  Are the backing plates different??  Will it work if I use the shoes, spring kit and drums???  Thanks.. Dan
Offline B67FSTB
  • President, StangFix Belgium
Re: 10" x 2" drums in place of 10" x 1-3/4"?
« Reply #1 on: May, 06, 2011, 06:25:59 AM »
Backing plate is a "must have" to do the conversion IIRC.
Brake cylinder , brake shoes and drums are different with a 10 X 2 set up.
Bruno
Offline Jonk67
  • Yak, Yak, Yak
  • Smyrna, TN
« Reply #2 on: May, 06, 2011, 10:34:02 AM »
I'm going from recollection of last year and can verify this weekend but I swapped my 1 3/4" for 2" on a '69 9" but my 8" looked the same.
I did not have to change backing plates, I bought 10X2" shoes, raybestos drums for 10X2". The only other item that was different and prompted a trip to the parts store was the brake spring hold down pin that goes through the shoe. The 1 1/2" shoe pins were too short and the store had 2 other lenghts. I bought both and returned the box that didn't fit (I think they were for 11X2 1/2" shoes so they were too long TMR).
Using the 1/2" wider shoes and drums did not push my tires out any farther but I didn't bother to see what was different about the drums that allowed this. I think the 1 1/2" drums had 2" wide pad surface and the thinner shoes just didn't touch the entire width.
Jon
