Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Home
Help
Login
Register
StangFix.com Forums
Forum
1964 1/2 through 1973 Mustang Boards
Engine and Drivetrain Board
What should i look out for when buying used heads: updated need some advice!!!!
Random Image from the Gallery
Latest Victims
TFOB
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: What should i look out for when buying used heads: updated need some advice!!!! (Read 898 times)
pnandy
Valued Member
Did i tell you about the time i met Emilio Estevez
on:
March, 03, 2009, 11:24:04 AM »
I'm going out this weekend to take alook at a couple used gt40 heads i've already found all the gt40 casting numbers so i can compare to make sure they are gt40 heads.
Is there anything i should look out for before i buy the heads?
thanks for help in advance
Last Edit: March, 17, 2009, 02:49:16 PM by pnandy
Logged
Patrick
Fast68back
Administrator
Shutup Already
You want fries with that?
Re: What should i look out for when buying used heads
Reply #1 on:
March, 03, 2009, 11:36:40 AM »
Cracks............ Take a straight edge with you and run it across the hed and make sure they are not warped.
Logged
pnandy
Valued Member
Reply #2 on:
March, 03, 2009, 06:47:07 PM »
whats a good price for low mileage gt40 heads that are in good condition. Found out the place thats selling them is a machine shop
Logged
Fast68back
Administrator
Shutup Already
Reply #3 on:
March, 03, 2009, 06:54:30 PM »
Machine shop is a good thing..... I have no idea on cost, I'd check a few sites and get an average price, check a few big city craigslist, ebay, 5.0 forums, etc.
Logged
pnandy
Valued Member
Reply #4 on:
March, 17, 2009, 02:48:01 PM »
picked up the heads yesterday got there right as he started taking them off. engine had about 50k on it thought about just buying the whole engine for awhile because of the overall condition it was in was very good.
im going to switch out my cam to when i swap the heads what would be a good comp cam to go with these heads im looking for one with a fairly aggressive sounding idle. should i get new lifters to if so which ones.
I have the stock gt40 rockers would it be a good idea to switch these if so what do you guys recommend
thanks for the help in advance
car spces motor 84 302 5.0l carbed 4 speed 9inch 3.50
Last Edit: March, 17, 2009, 02:53:02 PM by pnandy
Logged
Fast68back
Administrator
Shutup Already
Re: What should i look out for when buying used heads: updated need some advice!!!!
Reply #5 on:
March, 18, 2009, 01:13:20 PM »
Why are you switching the cam, looking for more? For less? Seems like the e303 cam is very polular. Find out what you want from a cam and then do some research. Sounds like your building a fairly modern 5.0, I'd check around some of the late model boards and see what everyone is building using the pieces you have, late model block and heads, etc.
Logged
pnandy
Valued Member
Reply #6 on:
March, 18, 2009, 02:55:33 PM »
thinking the lobes may have gotten wiped out e303 is nice but i dont think i can used that cam shaft block is an 84 which i beleive is pre roller blocks heres my current cam
http://www.cranecams.com/index.php?show=browseParts&action=partSpec&partNumber=364382&lvl=2&prt=5
im pretty sure i want a little more i assume the gt40 heads can handle it to
Logged
Starfury
My car HATES me
Talks Too Much
Reply #7 on:
March, 19, 2009, 02:50:54 PM »
Hmm....that's a pretty high winding cam already, although lift isn't fantastic. But then, I don't know what kind of lift you can run with your bottom end. Do the '84 pistons have valve reliefs?
Also, don't choose a cam based on sound. You'll just end up with an unstreetable mess of a motor. The cam needs to be matched to the heads, drivetrain (gearing), and your driving style. Fill us in on the latter two and I'll see what I can come up with for a cam recommendation.
Logged
Tad H.
'67 fastback
331 stroker
3sp m/t
pnandy
Valued Member
Reply #8 on:
March, 26, 2009, 09:19:51 AM »
ok so ill give my car specs so you can help with the cam selection
thanks
mainly street driven fairly aggressive
9inch rear with 3.50s
4 speed
should i replace the rockers and lifters as well when i do this?
Logged
Starfury
My car HATES me
Talks Too Much
Reply #9 on:
March, 31, 2009, 09:14:47 AM »
You have to replace the lifters, it's not an option. Roller rockers (or at least roller-tip) would be a good idea, but not required.
I'll poke around tonight when I get home and see what cam I can come up with for you.
Logged
pnandy
Valued Member
Reply #10 on:
March, 31, 2009, 02:44:40 PM »
sounds good i figured the lifters and what not roller rockers sounds good to anything that gets it ready so i can send it off to get the a/c and paint and body done they will be changing all front accessories too. to fox body style setup with march brackets and pulleys it will be this kit in the link. ima do the cam lifters and heads etc and then have the installers replace the front acc to fox body wp alt and then used the march brackets
http://mustangforums.com/forum/classic-mustangs/527106-the-stangs-new-engine.html
the kit comes with alt and a/c bracket with tension and comes with all the pulleys.
so all i need to get is fox body alt water pump need new timing coverto right? and then when i order hte a/c kit i need a 505 or 508 a/c comppressor.
i think thats all i need if you can think of anything else please tell me.
so once my uncle can finish the cam lifters and heads its off to paint hopefully by mid may and then hopefully get it back mid june with everything done
please provide links to the selections if you can thanks
-patrick
Logged
Print
Pages: [
1
Go Up
« previous
next »
StangFix.com Forums
Forum
Powered by
EzPortal
