TFOB
Author Topic: Explorer 8.8 build DIY COMPLETE!!!  (Read 5098 times)
Offline 67FSTBKRestoMod
  • Quiet Type
    • The Masterpiece
« on: March, 26, 2011, 06:47:04 PM »
Thought i would go ahead and start a thread for anyone in the future thinking about doing this swap especially for 64-66 guys out there. I was always planing on putting a 9 in the back but after reading musgofasta's 8.8 thread i was inspired. I am however taking it a few steps further since i don't like the offset pinion and the added angle i'm narrowing it. i figured i could build this 8.8 for a fraction of what it would take to build a 9 the same way so monday i went to pick n pull and nabbed an 8.8 3.73 LSD from a 96 exploder and drug it home. Here she is when i first got here home monday.
I was able to tear it all down that night
to narrow it i first drilled out the plugs, starting with a smaller bit and working up to a 1/2 inch. I then used a chisel and hammer to smosh in the the head of the plug and pop it out. Then i used a 10 ton body ram to push the axle tube out, first marking the tube and diff housing for reference points for reinsert
Here is the rear with the tube out
markings
I then used a square for the markings
The tube needs to be shortened exactly 3 inches so that i can use another short side axle from yet another exploder.
Use a chop saw to make sure the cut is exactly square
i then beveled the edge to help assist in pushing the tube back in the diff housing using 36, 80 then 180 sand paper and remarked the markings.
Now for pushing the tube back in, this is where i had to get somewhat creative, i used a 12 ton pipe bender and a chain anchored to it to press the tube back into the housing
I then plug welded the the old press plug holes
After that i removed all the rest of the brackets and sanded down the axle tubes to get rid of little inconsistencies for measuring the tubes.
Cleaned up the edges where it will be welded
doing about 3/4 at a time i welded the tubes to the housing allowing plenty of time to cool between welds and constantly measuring the tubes with a digital angle finder to make sure the tubes don't move. I was successful in keeping the tubes from warping or moving.
I then cut off the bracket location, this is not necessary i just didn't like it.
Here it is as it sits now,
I'll update more as it comes along.
Cost so far
Complete rear end: $150
Short side axle: $17
« Last Edit: April, 02, 2011, 06:48:48 PM by 67FSTBKRestoMod »
Offline apollard
Re: Explorer 8.8 build DIY
« Reply #1 on: March, 26, 2011, 06:52:27 PM »
Nice work looking forward to the rest of your post.
Offline abrahamfh
  • Photophiliac.
  • keeping it old school
« Reply #2 on: March, 26, 2011, 07:00:46 PM »
WoW. I am speechless.
Can't wait for your next update.
              MEET FRED!
Offline fordrule
  • back into the world of mustangs..once I get back
« Reply #3 on: March, 26, 2011, 08:01:07 PM »
damn...speechless..want todo mine lol...looks like all you have left todo is just remount the spring perches but i am sure you are going to test fit it in the 65-6 and tact the perches where you need them and then go back and reweld the perches and then make the exterior look pretty and then reassemble the rearend with new gaskets, seals and bearings...
65 t code coupe.... 200ci/c4 whimbleton white...dubbed jo-jo 12 yrs ago.....
currently she has become project mayhem.. still having dreams of 8 cylinders..but currently living in 6 cylinder reality..
I wanna go fast....
  • Quiet Type
    • The Masterpiece
« Reply #4 on: March, 26, 2011, 08:23:52 PM »
That is the plan only its going into a 67 not a 65-66. I wanted something a little narrower than stock so that was a bonus with getting rid of the pinion offset and its added angle.
Offline fordrule
« Reply #5 on: March, 26, 2011, 08:34:38 PM »
i dont have the rear end yet so i am not sure exactly how much i am needing to cut off the tube to fit in my 65. I understand the use of another short side exploder axle will work just fine unless I want to use currie axles
Offline B67FSTB
  • President, StangFix Belgium
« Reply #6 on: March, 26, 2011, 10:18:58 PM »
 :thu :thu  very good !!
Bruno
  • Quiet Type
    • The Masterpiece
« Reply #7 on: March, 27, 2011, 08:33:51 AM »
I'll measure when its all put together to confirm but here is what i get out of it. 65 is 57 1/4 the explorer is 59 1/2. i took off 3 inches making it 56 1/2 so that would would put it 3/4 shorter than ur stock axle, 3/8 shorter on each side. not to bad. if ur going with currie or something to that affect you should be able to get the axles in any length so you could narrow it to exactly 57 1/4
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #8 on: March, 27, 2011, 06:11:37 PM »
this is a really cool thread and even though I probably won't do a 8.8 myself it's neet to see. However, I gotta ask, what is going on the with the foot in this picture?
  • Quiet Type
    • The Masterpiece
« Reply #9 on: March, 28, 2011, 09:28:07 AM »
HAHAHAHA I didn't even notice that was the one i put in, that was my gf attempting to screw up all my photo shots, looks like she succeeded in one! how bout the little rat dog under her to boot!
Offline AzPete
  • Classic...less
« Reply #10 on: March, 28, 2011, 09:44:34 AM »
Nothing is screwed up....just another picture of a rear end. She could at least pick more interesting body parts to randomly expose in your pictures...... As for the rat dog....well, it is a rat dog.....
USAF/Ret.
7 Previously owned..66-07
  • Quiet Type
    • The Masterpiece
« Reply #11 on: March, 28, 2011, 05:21:16 PM »
I told her next time there better at least be a little leg in it!
Got a little work done yesterday and today.
I'm using the old abs sensor as a fill, i welded up the bolt hole then threaded the sensor hole which i will use a bolt in place for filling the diff up.
I decided to use the old spring perches, 2 reasons: save me $20 and i wanted to use them so i could keep the original brake mounting points so i wouldn't have to fab something up.  i did have to close the mounting hole up a bit so there wasn't any play
I then welded em at 3* positive or up whatever u wanna call it using a digital angle finder. same way as before, 3/4 at a time
Today i sand blasted it, btw cast is a b*#ch to blast
Then 2 coats epoxy primer till i decide what i want to do for color, i'm stuck between a gloss black and the orange of the car
Offline stangg
« Reply #12 on: March, 28, 2011, 05:31:39 PM »
Great write up,  the rear end looks great...   So for less than $200 you've got a restored shortened, disk brake, 31 spline, 3.55/3.73 equipped traction lok... nice!!!
btw... keep it black - looks perfect and will compliment the orange...
Offline AzPete
  • Classic...less
« Reply #13 on: March, 28, 2011, 05:50:01 PM »
Nice job for sure plus easy reference.
Offline fordrule
« Reply #14 on: March, 28, 2011, 05:57:20 PM »
been bookmarked for my future endevors
Offline monkeystash
« Reply #15 on: March, 29, 2011, 08:35:33 AM »
WOW, great write-up and even better fab skills!
-Ryan
  • Quiet Type
    • The Masterpiece
« Reply #16 on: March, 30, 2011, 08:30:18 PM »
Thanks for the words guys, stangg i'm going to take and use ur opinion, i'm pretty positive ur right. Got some updates on the rear for ya
Sandblasted the dust shields
two coats epoxy primer
New axle housing bearings and seals
I pressed them in using a BFH, a 2X4 wrapped in a towel and the old bearing to get them completely seated. Tested tried and true method!
New pinion seal and parking brake shoes
Pressed the seal in using that same BFH and 2X4
Installed the bracket, dust shield and parking brake components
Installed the pinion, diff and axles per the manual. everything went in with ease
The brake calipers were in very good shape, just extremely dirty
I disassembled em then blasted them
I then powder coated them with some of the leftovers from the front calipers and rebuilt them
Almost done, just  need to throw the diff cover on, get new rotors and pads and fill  her up
Total cost so far (actually lookin at receipts this time)
Complete rear end:  $152.98
Another Short Side Axle:  $17.28
2 Wheel bearings and seals:  $ 43.78
Pinion Seal: $4.99
Parking brake shoes:  $20.99
Gear lube(2 qrts could go up we'll see): $37.98
Friction Modifier:  $6.49
Total Cost so far:  $284.49
Offline 66benchcoupe
  • Quiet Type
« Reply #17 on: March, 30, 2011, 08:59:06 PM »
Nice work!  That's some pricey gear lube. . .
Robert
1966 Coupe
1991 GT
  • Quiet Type
    • The Masterpiece
« Reply #18 on: April, 02, 2011, 06:48:09 PM »
Thanks Robert, yeah, ripoff!!!!
Yet another update, the last actually
I'm installing a 4-link so this might not apply to some.
I had to get the rear installed, set pinion angle and weld the brackets to rear for the 4-link.
After it was centered and the pinion angle was right i tack welded the brackets on and pulled her out to fully weld them. welded them the same as everything else 3/4 at a time allowing to cool between welds.
polished the brass on all the brake lines
I first touched up the paint then I assembled all the odds and ends, rotors, calipers and then also bent new ss lines since i'm going to be doing all new ss plumbing. the old line can be used with tweeking.
Going in for final install
Everything buttoned up
This is the ride hight with the bags fully decompressed with the crappy old small wheels that came with my coupe
Pinion Seal: $4.99
New rotors/pads: $57.87
Grand Total: $342.36
Not bad at all
There ya have it. Hope this will help somebody out someday
« Last Edit: April, 02, 2011, 06:50:53 PM by 67FSTBKRestoMod »
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
Re: Explorer 8.8 build DIY COMPLETE!!!
« Reply #19 on: April, 02, 2011, 06:57:46 PM »
very cool build-up and pics. I think my son and I will do this on his Falcon. Thanks
Offline fordrule
« Reply #20 on: April, 02, 2011, 08:09:37 PM »
yes indeed, i just found a rear end for 100 bux..now i just got to find another short axle to be good..where did you find another short axle for that inexpensive?
  • Quiet Type
    • The Masterpiece
« Reply #21 on: April, 02, 2011, 08:34:59 PM »
Pick n pull formerly pull a part, took apart the rear and just took the short side axle out.
  • Quiet Type
    • The Masterpiece
« Reply #22 on: April, 21, 2011, 07:27:02 PM »
Wanted to add how i tackled the little parking brake problem. I took the parking brake cables with the rear when i bought it so i cut the little fittings off the explorers cables, keep the springs they will be used and cut a slit down the center of it a little bit with a 3" cut off wheel.
Cut off the old drum fittings from the stangs parking cable, Spring first then slip that puppy in that slit and weld part way up the slit DO NOT GO ALL THE WAY. welding the cable causes it to fatigue and break when twisted bent, really moved in anyway and the cable will start to split. Doing it half way insures the cable that is moved around will not split and break.
There ya have it
And for those that dont wanna spend the time i found these guys
http://www.speedwaymotors.com/E-Brake-Clevis-for-Ford-Explorer-and-Wilwood,37008.html
Offline Federico Garza
  • Found it!
« Reply #23 on: May, 05, 2011, 11:23:59 AM »
Nice work, mind sharing what you used to weld the tubes to the center section TIG/MIG or Arc???
  • Quiet Type
    • The Masterpiece
« Reply #24 on: May, 11, 2011, 10:42:39 AM »
Regular old MIG, I think TIG with some sort of nickel rod would have been the best way to go but IMO this is more than sufficient.
