TFOB
Author Topic: Hell of a Monday - Thrust Bearing gone!  (Read 843 times)
Offline Horseplay
Re: Hell of a Monday - Thrust Bearing gone!
« Reply #25 on: March, 23, 2011, 09:57:32 AM »
Because you are initiating lateral motion and force against the crank when you do
Offline RyanG85
« Reply #26 on: March, 23, 2011, 10:59:35 AM »
Pushing clutch pushes the pressure plate into the flywheel which in turn puts force onto the crank and thrust bearings...
Offline stangg
« Reply #27 on: March, 23, 2011, 12:16:10 PM »
With no load at idle the crank is probabaly near the center.   When you press in the clutch, the throwout bearing applies pressure to the fingers on the pressure plate,  Since the pressure plate fingers are spring loaded and firmly attached to the flywheel / crank, the whole assembly will move forward until the crank meets the thrust bearing,  and then the pressure plate fingers will start moving under heavy load in order to seperate the pressure plate from the clutch disk...
When the pedal is released,  the crank probably just floats back to it's natural running position.
Offline mmw68
  • Opening Beers around the world
    • cruisercrap.com
« Reply #28 on: March, 23, 2011, 12:33:02 PM »
Thanks everyone - this has been a wonderful education. I just received a phone message that the noise is gone, and it was a easy fix. So as soon as I finish up work, I'll head over there to get the scoop. don't have much details, but he mentioned something about the starter?
-Mark
Mark (mmw68)
Austin, Texas
http://www.cruisercrap.com
Vintage Air Dealer, and Sound Heat Deadener
Offline Horseplay
« Reply #29 on: March, 23, 2011, 12:49:43 PM »
Do come back with details. Realize, you can have wear that will allow a small amount of crank movement but if you really have as much as first stated...IDK
Offline mmw68
    • cruisercrap.com
« Reply #30 on: March, 23, 2011, 01:11:57 PM »
I know, I know... I just got off the phone with him, They had to use a shim to get the starter to clear. That is what was making all the noise.
But, it makes me think....
What was the marks on the flex-plate from? I  never saw the flex plate off the car until now, so I don't know if that was a old flex plate, and someone decided to reuse, and my car made those marks or what the full story is.
Also -  I got a box O' parts with this engine, two different Starters, and just grabbed the one that looked the best. From a quick google search, it does seem there is a difference in auto/manual starters. Lots of threads on a few of the mustang forums.
Iam going to make him measure the crank end play in front of me. I might of been hasty in saying 1/4, I'll get some facts and report back. -Mark
Offline Horseplay
« Reply #31 on: March, 23, 2011, 01:17:54 PM »
Just 'cause I can't help myself...
flexplates are for autos, flywheels are for manuals
Offline mmw68
    • cruisercrap.com
« Reply #32 on: March, 23, 2011, 01:27:06 PM »
Dohu!  ;)
OK - the "Block Plate"
http://www.mustangmagicparts.com/motorcraft-d9zz7007a-plate-ass97007.html
Also - comparing the FORD part to the blocking plate we took off the car, the ripped up one was very thin compared to the ford one. So maybe it was flexing??
« Last Edit: March, 23, 2011, 01:28:57 PM by mmw68 »
Offline RyanG85
« Reply #33 on: March, 23, 2011, 02:13:54 PM »
Hope it was that simple. Like you said, have them measure the end play in front of you just for piece of mind.
Offline Sluggo
  • How you like dat Jake?
    • www.StangFix.com
« Reply #34 on: March, 23, 2011, 05:50:50 PM »
Was it a T5 block plate? I had to change it when I converted from auto.
Offline mmw68
    • cruisercrap.com
« Reply #35 on: March, 24, 2011, 06:49:54 AM »
Yep - T5 Block plate.
Yesterday's drive home was interesting, It seems I have a short in my electric fuel pump wiring.
But, aside from that, it drove fine. I arrived to late to have them measure the Bearing in front of me, but Iam still going to get that done.
