Linux Mint 11 Rulez....
It's the most ridiculous idea in the last 50 years, burning our raw food for fuel. Now if they made it from the waste, I could support it.
We already have around 10% ethanol in the gas around here.The Mustang runs "ok" with it but would certainly run better with pure gas. My step dad takes a long drive to buy "real" gas for his boat because at even 10% his boat runs like shart with the ethanol stuff.I've considered eventually converting my Stang to fuel injection with an overdrive tranny. If they screw with the gas much I may go ahead and do so....
My Mustang has everything new, including gas tank, fuel pump, fuel lines, carb, etc. etc. so I have only used E10 since the rebuild. There was no build-up for the ethanol to break loose. In say a car that had not been totally rebuilt or restored or a boat for example, there could be build-up that the E10 starts to dissolve in the fuel and make it run bad.
The only thing that I'm hearing we should be aware of is the amount of potential rust developing in your standard steel fuel lines, so we should consider going SS.
If we are replacing the line to the tank, would braided steel hose work? Alcohol racecars use it.
