TFOB
Author Topic: DOH! electrical snafu in the shop  (Read 523 times)
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« on: February, 14, 2011, 07:21:17 PM »
I just finished running the feed to the sub panel in my outdoor shed.  I had the shed itself wired for about a year now and just got around to digging the ditch for the feed.
As I was wiring up the main breaker in the sub panel, I noticed that my 30A 240V circuit to my 30A outlet for the air compressor was wired with 10-2 instead of 10-3.
@#$%%^^!!  WTH was I thinking when I did that?
Fortunately I noticed it before I tried hooking up the compressor.
Can I just get 25 feet of single #10 solid copper to run the second hot wire with, or do I need to yank out the 10-2 and replace it with 10-3?  I guess the real question is, can you wire a circuit with 2 separate wires or does it need to all be within the same romex sheathing?
Sam
Member number 427
68 Coupe
Offline lethal289
  • Steel Hoods Rule!
Re: DOH! electrical snafu in the shop
« Reply #1 on: February, 14, 2011, 08:46:19 PM »
You could pull another 10-2 wire.  And cut off the non used wire.  IMO, its better to have a sheath for extra protection instead of a single 10 gauge wire, but all 3 wires need not be in the same sheath.  But if you have to buy more 10-2 to do that, you might as well just run the 10-3.
Offline B67FSTB
  • President, StangFix Belgium
« Reply #2 on: February, 15, 2011, 08:14:22 AM »
Connect the new 10-3 feed to a end of the 10-2 feed and pull it through the ditch ??  Possible ? :confu :confu
« Last Edit: February, 15, 2011, 08:28:56 AM by B67FSTB »
Bruno
Offline Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
« Reply #3 on: February, 15, 2011, 09:33:10 AM »
Have you thought about going to the wireless system?   :yah
Panama City, FL
Offline apollard
« Reply #4 on: February, 15, 2011, 10:41:46 AM »
You can - it will work fine. However, you might have an issue if you sell the house. Inspectors won't like it, and some states codes require sheathed cables in 'exposed' (read: accesible) wiring locations.
But, you can deal with that then, doesn't sound like your moving soon...
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« Reply #5 on: February, 15, 2011, 11:36:30 AM »
OK, something to think about then.  Will most likely just yank the 10-2 and replace it with 10-3.
Fortunately the wire in the ditch is fine, I just need to fix the line from the sub panel to the compressor in the shed itself.  The existing 10-2 wire is run up the wall that the panel is on, then through the ceiling and down the wall the compressor is on.
Offline B67FSTB
« Reply #6 on: February, 15, 2011, 12:19:18 PM »
I think you are a bit lazy today !!! :roll :roll :roll
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« Reply #7 on: February, 15, 2011, 01:51:25 PM »
How so?
Offline B67FSTB
« Reply #8 on: February, 16, 2011, 03:49:06 AM »
Think that it isn't that much of work to rewire.Or isn't the existing wire feed channelled in a plastic tube?? ( don't know the exact term)
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« Reply #9 on: February, 16, 2011, 04:51:39 AM »
Oh, gotcha.  Yeah, I don't mind doing the work, its just painful right now buying copper.  50 feet of 10-3 is $100 these days.  That's crazy.
Offline B67FSTB
« Reply #10 on: February, 16, 2011, 09:14:28 AM »
Yep , it hurts paying twice for material and doing the same job all over again.  :bomb :bomb
Offline stangg
« Reply #11 on: February, 16, 2011, 01:16:07 PM »
Is that a Home Depot price?   I found that buying materials at an electrical supply store is typically less expensive than buying from HD / Lowes etc... If you go to the places that tend to deal with tradesmen more, you tend to get pricing closer to what they get.
