TFOB
Author Topic: Do mod motors need higher hood for '67 mustang?  (Read 238 times)
Offline scubadds
  • Quiet Type
« on: February, 02, 2011, 05:32:41 AM »
I am far from this, but trying to decide if I want a stock hood, or to use the E hood I have.
I have the R&C MII crossmember in and shock towers out in my '67 fb
My question, if I put newer mustang motor mod or Coyote motor in will it fit under the stock hood?
I thought I read they were tall and needed taller hood to clear.
If the above answer is "it want fit"; what about an eleanor hood, does that rise help?
Thanks so much
BT
'67 Fastback, undergoing restomod to a gt500
Offline mustangstofear
    • Mustangs To Fear
Re: Do mod motors need higher hood for '67 mustang?
« Reply #1 on: February, 02, 2011, 06:19:51 AM »
What nose are you using? We make the higher E hood for clearance, and we just came out with our new MTF style hood that has a little more rise to it. Both of our hoods are for the long style. Rich.
Offline scubadds
  • Quiet Type
« Reply #2 on: February, 02, 2011, 06:34:26 AM »
thanks Rich,
I've yet to get those engine bay panels installed but they look nice
Based on your statement, I gather the new motors are taller and do require taller hood???
I hate to say, I am trying to avoid too much hood rise.
Not sure what pertinant info you needed, but I bought an E kit a few years back; I can't recall the maker, but it doesn't have a very high hood. It looks like the "normal" e-kit as far as the longer front end.
I was given a stock hood, to help fit things back together as the e-hood is oversized.
I like the look of the Ekit lower front valance and then the stock bumper and stock-ish hood. (at least as far as I can tell laying pieces together in the garage)
I can't decide if I should plan on modern EFI or just throw a 351w carb. in.
Hated to get to the end and realize I planned poorly
Thanks all
« Last Edit: February, 02, 2011, 06:42:41 AM by scubadds »
Offline Fast68back
« Reply #3 on: February, 02, 2011, 08:27:57 AM »
Check out colemans build thread, he has some pictures with his mod motor installed
http://www.stangfix.com/testforum2/index.php/topic,8928.0.html
« Last Edit: February, 02, 2011, 10:46:46 AM by Fast68back »
    • Mustangs To Fear
« Reply #4 on: February, 02, 2011, 08:39:13 AM »
Yes, the mod motors do require more clearance. I plan on going wit the FAST system on my next build. Rich.
