Dennis,Let me know if you have any thoughts on where i should measure? I'm not sure I follow on the tail light panel?In the mean time, can you measure the trap door opeing in the shell?I had to remove the pieces on one side to fix some rust. I took a bunch of measurements, but of course I forgot the one that appears to be most critical to actuall putting this stuff back in the right place.I'm thinking I need the width at the top and the bottom in case the opeing isn't square. I think it should be square, but I''ve been bitten in the past on this car when I guess where something should be.Pics of what I did below:
Dennis,Do you know what in those holes? Mine had the remains of rivets. I thought that must not have been factory, so on the one side, I welded them closed. Guess I got to put them back...
Dennis, both Red and Shag have full trunk carpet kits so they won't do any good to take measurements (besides they don't want me messin' with them) but I will have access to a 67 FB for a couple weeks which still has a empty trunk (but the tank is in place) and can take some measurements as needed. Maybe if you supply pics of what you want measured indicating with either a measuring tape, we can then duplicate the pose with our own measurements. Yes it looks like per NPD's catalog, these drop off were the same from 65 thru 70
Looks like they sent you the wrong ones, I always have to trim the bottom edge off. Rich.
