IIRC when you have 2 resistors then you have 3 different speeds of the blower motor.
Highest resistor is first speed , lowest resistor is second speed and NO resistor is full speed of the blower motor.
Keep in mind that the + pole of the blower motor directly connected is to a positive terminal and that the - pole from the blower motor is conected to the resistors and from there on it goes , through different wires , to the control panel to find its ground.Which of those wires is grounded determines speed of the blower motor .As said earlier on , grounding the control panel is very important !!
