Section the seat pans front & rear, leaving the bottoms and the hump intact, then extend the hump down to meet....?
I really didn't want to compromise something that I added for strength reasons...
Aren't they the same height as the coupes and fastbacks? I took 1 1/4"+/- out of the front and back both and it still left an inch or so vertical in the back. Way more complicated, but probably could be done.edit: and I just lapped the section, so it doubled the vertical walls.
I haven't measured but I'm sure they are the same. The issue is that the entire point of putting the convertible seat pan in is to build beam strength from one rocker, over the trans. hump to the other rocker. By lowering the pan and shortening the vertical front/back piece I'm reducing the beam strength unless it gets reinforced somehow.The weekend is coming, I'll figure something out.
That looks great!!! So are you not putting the lower pans in due to the TCP X brace? If not, is there any clearance between the brace and the floor? On the top pans, I think some gussetts laid at an angle at the corners after installation would be about all you need to beef the corners back up.
So Shaun, after you welded everything up, did it feel more flimsy? I'm just wondering why you think it lost so much strength, it has all the metal and boxing it previously had??
The main point of the 1 piece seat pan is to strengthen the unibody between the rockers. The vertical portions of the riser is where the majority of that load is transferred across. What used to be about an inch and a half of vertical wall at the base of the trans tunnel is now cut down to about a 1/2 -3/4" (guessing on the actual measurenment) but that where the loss is... I'm pretty sure adding some flat stock diagonally from the vertical to the edge of the flange will beef that section up by essentially boxing that corner. IMO, that's where the weekness is... how severe probably not much, but theoretically narrow paths, with sharp cornes isn't necessarily a good thing...
Shaun,Great work! It looks awesome!Not to hijack your thread, but I have a question that is somewhat related to your project. I'm wanting to replace the under-dash parking brake with a hand brake mounted on the trans tunnel.The big knock is that I've got a convertible with the reinforced seat pan and the optimal mounting position for the hand brake is smack dab in the middle of the reinforced ridges. Any ideas on how to do this so that I don't loose any strength?Any ideas would be appreciated,-Shannon
Very nice workmanship Shaun... it looks like you have it very well covered with everything you've got going on there.
