Tomorrow, Red or Shag is bringing over some welding supplies and words of encouragement to our Abester. Maybe I'll go as well.
Abe , you did make some mistakes .... that every beginner does .So listen and TRY what they all say, like spot welding ,using copper a backing ect ect.But you need to practice alot on scrap metal before you do this on your own car.Thats all I want to say.You are doing great by trying it and you don't hasitate to ask people.Keep it going.Your welding skills will improve by DOING it.B.
Maybe you could practise in the meantime by trying to put the patch back into the repro panel you took it out of. :)
Good idea !! so Abe , you know what to do beside going to get some beer for Craig.
Where you aim your electrode also has a lot to do with the blow through since the thinner metal can't take as much heat as the thicker metal can. When you aim your wire, favor the cleaner / thicker metal to start the puddle, and then drift it towards the thinner metal.
Sheut. I'm not a master welder. See -I didn't even know to not use AL as a backer! Not that I ever really need to use a backer though. But if I did - I would have used my piece of AL.
