TFOB
Author Topic: 1970 Gauge Conversion. Finished & Pic's  (Read 830 times)
Offline Larry G
« on: December, 30, 2010, 09:25:29 AM »
 Hi All
I've started the gauge update/conversion on my 70 Mach and looking for a little help.
I know this conversion has been done on "69/70" dash bezel but there's not much info out there about it, so if anyone has any tips, hints, suggestions or most of all pictures (especially of the back with gauges mounted) would help bunch's.
« Last Edit: January, 07, 2011, 01:19:54 PM by Larry G »
1970 Mach1 Retirement Project
"Done but never Finished"
Offline miketyler
Re: 1970 Gauge Conversion.
« Reply #1 on: December, 30, 2010, 12:45:00 PM »
What exactly are you converting to? I am putting in a 69 tach panel in my 70 and got Midlife to do the harness conversion. Hopefully no smoke when I get it installed  :skul
Offline Larry G
« Reply #2 on: December, 30, 2010, 03:46:32 PM »
I'm converting the stock ford gauges, that didn't work to Autometer gauges using the existing gauge bezel.
When I got my car back from paint last spring I installed a Painless harness and I knew I was going to be doing the new gauges I didn't worry about getting the old gauges working. I did have working (new) oil pressure and water temp. gauges.
Offline buening
« Reply #3 on: January, 03, 2011, 10:04:36 AM »
Jeremy (70 Fastback) did this same thing using the factory housing. http://www.stangfix.com/testforum2/index.php/topic,1278.msg101269.html#msg101269
There was also a website from KVinkler on VMF that did it but apparently that site is no longer valid:  http://www.geocities.com/kvinkler/    I'm not sure if you can find it in some online archive.  I'm not that computer savvy
Custom Motor Mounts
T56 Conversion
Offline buening
« Reply #4 on: January, 03, 2011, 10:06:02 AM »
Offline Fast68back
« Reply #5 on: January, 03, 2011, 11:25:45 AM »
Ya know, we have a tech article board here on Stangfix.......
http://www.stangfix.com/testforum2/index.php/topic,14.0.html
Offline Larry G
« Reply #6 on: January, 03, 2011, 12:12:05 PM »
Thanks for locating the pictures of Kevin V.'s coversion pictures, I did a bunch of searches but came up empty.
I knew Jeremy did the conversion and also Johnpro and I'm sure a few others, but I wanted to see some backside pic.'s.
Both Kevin and Jeremy used 5" Speedo & Tech gauges but it looks like Johnpro used the smaller 3 3/8" gauges so I'm still up in the air about watch size to use.
I do have a 5" tach but I'm not liking the way it looks in my cluster, a lot of the markings are covered by the stock bezel. Kevin and Jeremy's look like they fit a bit better, I'm not sure why, though.
I'll keep working on the conversion, lets see what I come up with.
Thanks Again the pictures do help.
Offline buening
« Reply #7 on: January, 03, 2011, 05:46:40 PM »
No problem!  I will eventually pull the trigger on the silver Stewart Warner Maximum Performance gauges. I plan on using 5" speedo and tach, with 2 5/8" gauges.   I never paid attention that the gauge bezel doesn't show with the 5" ones but it does nicely with the 3 3/8".  I like the larger gauge face though.  hmmmmm
What do you plan on using for the two side gauges?
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
« Reply #8 on: January, 03, 2011, 07:53:48 PM »
Larry, I just looked through all of my pictures from the conversion and I don't have a single one of the mounting of the gauges.  I guess I didn't take in between progress pictures.
My apologies.
Offline Larry G
« Reply #9 on: January, 03, 2011, 08:09:09 PM »
I sort of got the 5" tach to fit and look pretty good.
I ordered the 3 3/8" gauges and I'll see how they fit, look and see if these old eyes can read them.
For the two side gauges I'm using 2 5/8" with the silver rings and glass removed, I like the way they look and fit.
With the rings left on the gauges don't go in the stock bezel far enough.
I'll be posting pictures of what I did when the job is completed.
Offline Larry G
« Reply #10 on: January, 03, 2011, 08:16:31 PM »
Jeremy, Thanks for checking.
I pretty sure the pictures I saw back whenever were for the conversion that Kevin Vinkler did.I just couldn't find them, but thanks to buening for finding the post that had the links I now have the pictures. My setup will be different but it got me going in the right direction.
Offline 70_Fastback
« Reply #11 on: January, 04, 2011, 07:34:09 AM »
You'r welcome.  And I didn't do it like Kevin did either.  I actually re-used that metal backing piece, cut it as required and used it to hold my gauges in.
Offline Larry G
« Reply #12 on: January, 04, 2011, 08:10:05 AM »
I'm going to be using the rear metal pieces also, I've cut the outside pieces already and they hold the gauges in nice and tight.
The big center piece will hold the dash bezel where it belongs.
Offline 70_Fastback
« Reply #13 on: January, 04, 2011, 08:19:32 AM »
Great minds think a like.   :thu
Offline Larry G
« Reply #14 on: January, 06, 2011, 11:13:56 AM »
 Well I figured out what I'm doing with the gauge conversion and things are moving along pretty good.
I'm going with 2 5/8" gauges on the outside, oil pressure & water temp., and 3 3/8" speedo & tach.
I removed the silver rings and glass on all the gauges because I thought there was to much going on in the stock bezel and I am using the stock gauge lens.
Everything mocked up, just need to do some painting of the old bezel and I'll be ready for some wiring.
Here's some pictures of the mock up. :bowdown
Offline buening
Re: 1970 Gauge Conversion. Update & Pic's
« Reply #15 on: January, 06, 2011, 11:28:46 AM »
That turned out well Larry!  Did you have to use any filler rings for the tach/speedo since they are 3 3/8"?  Wasn't sure if the out-to-out dimension of the gauge fills the stock hole all the way.
Offline 70_Fastback
« Reply #16 on: January, 06, 2011, 11:39:29 AM »
Wow, I am impressed with the 3-3/8" fit & look.  I like it a lot!
Offline buening
« Reply #17 on: January, 06, 2011, 12:27:48 PM »
Yeah, its seriously making me rethink the 5" route
Offline rsalway
  • Active Poster
    • Ryan David Designs
« Reply #18 on: January, 06, 2011, 01:04:18 PM »
 :thu
Ryan
1967 Coupe (My First Car)
Offline DougG69
  • Cleveland Powered
« Reply #19 on: January, 06, 2011, 01:50:20 PM »
That looks really good!
Are you going to run a fuel gauge?
-Doug-
69 Mach 1 - 351c, TKO
Offline Larry G
« Reply #20 on: January, 06, 2011, 01:55:11 PM »
 Thanks guys, It is turning out pretty good, I was a bit worried because I was taking apart brand new gauges but so far I'm happy. Hope nothing goes wrong with them, I think I voided the warranty on them.
 Yes, I did use filler rings as the hole in the bezel measured 3 3/4" and the gauges with the rings removed where 3 3/8" (3 3/4" with the  rings but they still slipped through the bezel.
Fuel & Volt will be in the console pod. 2 1/16"
Here's a few more pic's of the filler rings. I'm sure you know what they are made from.
« Last Edit: January, 06, 2011, 01:57:12 PM by Larry G »
Offline 70_Fastback
« Reply #21 on: January, 06, 2011, 02:45:43 PM »
HAHAH!!  I love it!
Offline miketyler
« Reply #22 on: January, 07, 2011, 12:12:58 PM »
Wow - that does look pretty good. Got any pics with the woodgrain overlay in place?
Offline Larry G
« Reply #23 on: January, 07, 2011, 01:19:20 PM »
As a matter of fact I do, Just finished.  The chrome on the bezel was showing it's 40 years so I just painted everthing semi flat black and added a little silver behind the stock lens.
Here's the finished product.
         :bowdown
« Last Edit: January, 07, 2011, 06:59:20 PM by Larry G »
Offline SAC69
  • Yak, Yak, Yak
Re: 1970 Gauge Conversion. Finished & Pic's
« Reply #24 on: January, 07, 2011, 03:03:23 PM »
That looks great.  I've been following this thread with interest as I'm unsure whether it's better to refit the stock cluster + add the console gauges or use a 6-gauge unit like Year One, although it is a cheap-type plastic.
http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=E
---I apparently can't get a direct link to Year One's 69-70 Cluster.  For those interested, click on the link above, then on lthe eft-page menu, choose "interior," then scroll to "dash bezels and gauge clusters."
Your conversion came out great.
« Last Edit: January, 07, 2011, 03:07:03 PM by SAC69 »
Tom
a.m.d.g.
Go Navy!
