Linux Mint 11 Rulez....
Which bracket?I know Hooker Comps fir with AC and PS on my 69 with a windsor in it. The is also plenty of room for a stck z-bar if you are running a standard trans.
so I will need to add O2 sensors too.
My JBA H pipe had O2 bungs welded onto it already. They are capped for now.
For now? Thinking of switching to EFI sometime in the future?I've always understood that the O2 sensors should be as close to the collector as possible. While convenient, I'm not sure if the "H" pipe location is the best spot for the sensors.
