TFOB
Author Topic: New Ignition switch, no turn over...  (Read 326 times)
Offline southern_boy
  • Breakin' bolts & bustin' wires. One at a time.
« on: November, 30, 2010, 04:02:46 PM »
Alright, so I put the new ignition switch in, I just checked to make sure it was plugged in all the way. and it wont turn over. Why? I have power because the light is on. Any ideas?
Kevin Allen Bowers
Offline blue65coupe
  • Banned
  • where's my short bus
Re: New Ignition switch, no turn over...
« Reply #1 on: December, 01, 2010, 04:53:20 PM »
Turn it past "ACC"
sorry, couldn't help myself
Duane
« Reply #2 on: December, 01, 2010, 08:19:55 PM »
Turn it past "ACC"
It is past ACC lol
Offline AzPete
  • Classic...less
« Reply #3 on: December, 01, 2010, 08:24:13 PM »
If you have a wiring schematic, use it to verify ALL the wiring for the running of the car. If no schematic, get one and study it. They are not hard to figure out. With, what seems to be several issues surrounding the start and run of your car, you really need to check out the wiring for correctness.
USAF/Ret.
7 Previously owned..66-07
Offline Mach1Rider
  • Active Poster
« Reply #4 on: December, 02, 2010, 06:56:59 AM »
Did you adjust the switch after you installed it?
Loosen the nuts so switch will slide, turn key to acc position and slide switch downward to point where acc comes on and tighten nuts.
There should be a springback feeling now when you go to start position.
If its already broken...I can't hurt it!
« Reply #5 on: December, 02, 2010, 10:00:11 AM »
Should I just be able to turn the key to acc. Because Im not sure that any of my Acc. do work lol.
Offline Mach1Rider
  • Active Poster
« Reply #6 on: December, 03, 2010, 07:30:11 AM »
Yes if you use the volt meter attached to the acc lead on the switch to verify the connection was make before tightening the nuts.
If you have lights with the key in the on position, your problem of No crank could be in the sol red/blue wire is open.
Auto, check neut switch for adjust/connection.
Stick, insure jumper is connected at firewall plug
