TFOB
Author Topic: A bit of a teaser..(pics added)..  (Read 1640 times)
Offline AzPete
  • Classic...less
Re: A bit of a teaser..(pics added)..
« Reply #25 on: December, 02, 2010, 11:07:42 AM »
Wait.....for what......haha....
The skip shift actually does not work at parking lot speeds......just if you shift at about 3000 rpm. Short shift first and second is a blast.
Well, on to find some body parts...
USAF/Ret.
7 Previously owned..66-07
Online Kats66Pny
« Reply #26 on: December, 02, 2010, 11:14:43 AM »
If I had that car... I would have already had at least 5+ speeding tickets.
Offline AzPete
  • Classic...less
« Reply #27 on: December, 02, 2010, 11:38:15 AM »
Only if seen exceeding the limit......I cannot lie and say I have not done 65 in a 35........we will not admit to anything else. Those marks in the parking lot are not mine........
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
« Reply #28 on: December, 02, 2010, 01:44:35 PM »
No wonder your back is jacked up...
Your farking upside down...
Offline AzPete
  • Classic...less
« Reply #29 on: December, 02, 2010, 02:14:44 PM »
Oh crap.....will have to see a doc about that.....thanks for pointing that out for me.
Online Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
« Reply #30 on: December, 02, 2010, 03:37:34 PM »
Skip Shift?  What the he!! is that?  Someone explain that to me...I've never heard of it.
Panama City, FL
Offline AzPete
  • Classic...less
« Reply #31 on: December, 02, 2010, 04:09:57 PM »
According to the book.....you take off easy in 1st and get to about 3000 rpm. The dash info center tells you to shift to 4th...skipping 2/3 altogether. It is a mpg thing. Now, according to the manual, it indicates that you can ignore the message and shift normal....I find that the car electrically locks out 2nd and 3rd. According to other postings in some forums, it does lock out the two gears and forces you into 4th. It is odd for sure.
If you shift earlier in the rpm or drive it a bit harder, there is no skip shift. A performance tune also deletes the option.
I am still screwing with it to see if I can not take the 4th gear if I don't want to.
Without knowing what is happening, it makes one think they cannot drive a manual.
Online Midlife
  • DOM
« Reply #32 on: December, 02, 2010, 05:24:39 PM »
From first at 3000 rpm (probably 30 mph) to fourth (1:1)?  You gotta be kidding!  I can't drive the 06 in fourth below 40 mph or it begins to lug.
Offline AzPete
  • Classic...less
« Reply #33 on: December, 02, 2010, 05:42:57 PM »
5th is 1:1....got 6 total. It actually has good acceleration based on the way the computer manages the valve and cam timing. If ya got time Sat., I could let you take a look.....
For the 5.0L V8, shift according to the following chart:
Upshifts when accelerating (recommended for best fuel
economy)
Shift from (When not in skip shift mode):
1 - 2 17 mph (27 km/h)
2 - 3 25 mph (40 km/h)
3 - 4 40 mph (64 km/h)
4 - 5 45 mph (72 km/h)
5 - 6 50 mph (80 km/h)
Shift from (When skip shift mode active):
1-4 17 mph (27 km/h)
4-5 25 mph (40 km/h)
5-6 40 mph (64 km/h)
« Last Edit: December, 02, 2010, 05:58:08 PM by AzPete »
Online Midlife
  • DOM
« Reply #34 on: December, 02, 2010, 06:20:17 PM »
Still...from what you wrote, you're doing 25 mph in 5th gear (1:1) when you shift out of 4th!  NFW!
A pox on the new six speed!  I thought it was two overdrive gears, not 5 gears to get you to 1:1!
Offline AzPete
  • Classic...less
« Reply #35 on: December, 02, 2010, 06:34:29 PM »
Well, it works shifting that way but is no fun. I was impressed at it's ability top pull from low speeds in the higher gears....except 6th. That shifting info is out of the manual...
2011 6 speed
1st 3.66
2nd 2.43
3rd 1.69
4th 1.32
5th 1.00
6th 0.65
« Last Edit: December, 02, 2010, 06:36:52 PM by AzPete »
Offline SAWFISH50
  • Quiet Type
« Reply #36 on: December, 02, 2010, 06:50:24 PM »
The new 6 speed is totaly Bad ass. All the talk about the Skip shift might make you think other wise. I have the 3:73 rear gears in my car and just crusing around town I will usually row 1st to 3rd to 5th and grab 6th if Im on a long streatch of road going 55 or above, at 70 MPH on the freeway my car turns about 2100 rpm's in 6th gear and a down shift to 4th puts you in total Haul ass Mode for a quick pass.  If your driving your car "Like You Stold it" the skip shift never even turns on so no effect on laying the smack down on the foo in the GM next to you.  On the other hand as Pete has said just cruzing around town on Sunday you can skip gears and the car has plenty of power no lugging like my 91 5.0 would do in high gears at low speed.  The transmission is fine but my tires have problems in the first 3 gears  :roll
2011 5.0
Offline AzPete
  • Classic...less
« Reply #37 on: December, 02, 2010, 06:52:50 PM »
Mine has 3:55's in the back and I still have tire problems....also, gotta leave the traction button alone.
Offline blue65coupe
  • Banned
  • where's my short bus
« Reply #38 on: December, 02, 2010, 07:18:33 PM »
Sweet ride, good luck on the health issues.
Duane
Offline SAWFISH50
  • Quiet Type
« Reply #39 on: December, 02, 2010, 07:41:05 PM »
Step 1 Stoped with foot on break
Step 2 tap traction control button 2 times quickly = SPORT MODE
"Light em up"
Offline AzPete
  • Classic...less
« Reply #40 on: December, 02, 2010, 08:07:41 PM »
Interesting stuff here about it. Need to find a secluded lot now.....
http://mustangforums.com/forum/2005-2011-mustangs/620368-2011-gt-traction-control-button-question.html
