TFOB
Author Topic: Cheap Chinese heads...UPDATE April '12: IT'S ALIVE AND RUNNING!!  (Read 3295 times)
Offline GrabberOrange69
  • Better late than never......
  • Active Poster
  • Troglodyte
« on: November, 27, 2010, 06:59:54 PM »
Not to be confused with cheap head.
I just bought these on FleaBay http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=370453308843&ssPageName=STRK:MEWAX:IT.  They say you get what you pay for, so these should be good for a "Country Squire's" worth of cuss words and busted knuckles.
I was lured by the siren sound of low$$$.
Wish me luck
//////////////update Feb 2012////////////////
After a year of letting this project gather dust, I'm back at it (my job has been killing me - plus I've tinkered around with my '65 Coronet wagon).
Spent the whole day in the garage fly-cutting the pistons for the bigger valves in the Chinese heads.  Was pretty straight forward, just time consuming.
The fly-cutters are from Isky Cams, 2.05 and 1.65, and mount on pilots w/ adjustable stops...
...pop the cutter on the pilot...then I added wheel bearing grease to the cutting face to capture as much of the shavings as possible...
...then set the piston to top center, lay the head on the deck and finger snug the center head bolt...
...and turn the cutter with a tap handle.  Only have to put the head on and off the decks 16 times! LoL
////////////////////////////////////////////Update Mar 2012///////////////////////////////////////
Got 'em painted and bolted on today.  Here's the block deck while I was cleaning it - shows the notched piston...
Here's different views of the loaded up heads...
4 weeks left to get 'er done and on the road!
« Last Edit: April, 07, 2012, 08:48:54 PM by GrabberOrange69 »
Bryan
Online 67 Fastback
  • On 70_Fastback's "Shart" List...
  • Bill Watson
    • 67 Mustang Fastback Restoration
Re: Cheap Chinese heads...
« Reply #1 on: November, 27, 2010, 07:08:40 PM »
I hope you luck with them. After all the horror stories I've heard about them, I'd be leery.
Bill
LIVING THE DREAM OR RUNNING IT DOWN... HAVEN'T FIGURE OUT WHICH YET
  • Active Poster
  • Troglodyte
« Reply #2 on: November, 27, 2010, 07:38:08 PM »
They are a risk, but I have one ace in the hole - my dad owned a machine shop for 30 years before he sold it and retired.  He's going to check them out and tweak them if needed before i bolt them on.
Offline stangg
« Reply #3 on: November, 27, 2010, 07:45:26 PM »
I bought a set of those Floo Tek heads that were and sometimes still are being called Flo Tek... anyways,  I know they are not the same as what you got, but two disturbing things I found with the Floo Tek's...  First there were voids in the castings.  I saw them in the machined valve cover seal area but was leary of where else they may be.    Also,  the deck thickness in the combustion chamber area was thinner than the stock 5.0 cast iron heads E7 heads.  Aluminum heads should have thicker decks, not thinner...  Twisted Wedge I think is something like 1/2" and I think AFR is closer to 3/4...  that's a big difference compared to the less than 1/4" on the Floo Tek heads.   I'm not sure how the Pro Comp heads compare,  but just figured I'd point out some of the things I found.  Seeing that I had a brand new short block put together,  I didn't want to risk it with so so heads.   BTW if you need a set of inexpensive rockers,  let me know... I have a set of Pro Form 1.6 rollers that I didn't use since I ended up getting AFR pedestal mount heads.
« Last Edit: December, 11, 2010, 07:13:22 PM by stangg »
  • Active Poster
  • Troglodyte
« Reply #4 on: November, 27, 2010, 07:57:50 PM »
...I'm not sure how the Pro Comp heads compare,  but just figured I'd point out some of the things I found.  Seeing that I had a brand new short block put together,  I didn't want to risk it with so so heads.   BTW if you need a set of inexpensive rockers,  let me know... I have a set of Pro Form 1.6 rollers that I didn't use since I ended up getting AFR pedestal mount heads.
Thanks for the warning.  I think I have a set of rockers buried in the garage, but can't remember if they are bolt downs or stud type.  I'll PM you if need a set.
Offline RustyRed
« Reply #5 on: November, 27, 2010, 08:43:51 PM »
I first read the subject line on this one and thought it belonged in the old password protected boards, LOL!
When I was working on gathering parts for an engine build I was pretty tempted to get some of the cheap heads that are out there.
Then I decided to go with ported GT 40's that I found a good deal on, can't say I've had any regrets.
Coupes rule and Mark drools
  • Active Poster
  • Troglodyte
Re: Cheap Chinese heads...Update 7 Dec
« Reply #6 on: December, 07, 2010, 09:22:02 PM »
Cheap heads have arrived.  I'll get them torn down and report what I find:
Offline SAC69
  • Yak, Yak, Yak
Re: Cheap Chinese heads...UPDATE 7 Dec
« Reply #7 on: December, 08, 2010, 06:03:30 AM »
I've though about them too, simply due to the price, as they're approx 1/3 the cost of AFR's I'm eyeing.  Please let me know how they checkout.
Tom
a.m.d.g.
Go Navy!
Offline Starfury
  • My car HATES me
« Reply #8 on: December, 08, 2010, 06:31:34 AM »
I've heard Trick Flows are on sale at Summit right now.  $1000 for the street/strip heads.
Tad H.
'67 fastback
331 stroker
3sp m/t
Offline 65fast
  • Active Poster
« Reply #9 on: December, 08, 2010, 08:15:05 AM »
Im interested to see how the bolt holes line up on the deck as well as the VC mating surface.
Exercise Your Mustang
306
AFR 185's
FTI Roller .568/.570 - 218/230
Weiand Stealth
Toploader
9" 3.50 T-Lock
  • Active Poster
  • Troglodyte
« Reply #10 on: December, 08, 2010, 06:24:38 PM »
I'm dragging them over to dad's house on Sunday to check them out.  He kept enough stuff to do guide, valve and seat work, plus his straight edge.  So as long as the bolt holes are right we'll probably be ok.  Otherwise I have 2 expensive door stops.
Just as a reference they were $595 to my door, but if they are jacked-up, the twisted wedge @ $1000 will have been the way to go.
Offline pprince
  • 5F09C332634
    • Collector Vehicle Appraisals
« Reply #11 on: December, 10, 2010, 05:37:31 AM »
I bought a set of those Floo Tek heads that were and sometimes still are being called Flo Tek... anyways,  they were claimed to be australian castings by the dealer selling them but in reality were cast in China according to the stateside assembler
Hey man, this has already been beaten to death.
Alex says they are Australian castings. I do not believe he would lie.
1965 Mustang 2+2
prince-cva.ca
Offline pprince
  • 5F09C332634
« Reply #12 on: December, 10, 2010, 05:38:19 AM »
btw, $595 and free shipping is an incredible deal. I hope they work out for you.
  • Active Poster
  • Troglodyte
« Reply #13 on: December, 10, 2010, 06:40:11 AM »
I hope they work out too.  Yep, they were really cheap, especially for 210cc intakes, and I gues they hit my "wiggle" number to try them out.
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
« Reply #14 on: December, 10, 2010, 03:45:40 PM »
Good luck with the heads!  Let us know asap!
Offline stangg
« Reply #15 on: December, 10, 2010, 05:37:48 PM »
As mentioned I called the stateside assembler who happens to be Tri State Cylinder Head in Indiana.  They stated the castings come from China.
I later heard they carry a couple of sbf castings... some chinese, some australian,  it doesn't matter because ultimately I wasn't satisfied with the voids in the casting and the thinner decks and therefore returned them.  Chinese or Australian castings -  I really don't care... the point I was trying to make is that cheap heads could potentially have casting defects and you probably want to check them out thoroughly.  Trust but verify.... that's what I did...   this is one of the Floo Teks that I got.
What would you do?  Granted it's in the valve cover gasket area, but how could you verify that there aren't anymore above  the combustion chamber?  I wasn't willing to take that chance on a new shortblock
Anyway, the intent of my original post wasn't to throw jabs at Tri State Cylinder Head but rather highlight to the OP what some of the inexpensive head weakness' may be. Hopefully he has come across a nice inexpensive alternative.
Offline pprince
  • 5F09C332634
« Reply #16 on: December, 11, 2010, 12:17:05 PM »
That is definitely a defect.
I bought a set from Alex and they look fine.
This is his response to the China thing:
"I always love a uninformed individual who just has to spew some sort of garbage by spreading lies or rumors.
Our heads are cast in Australia, not China as many others on the market are.
They are assembled in Indiana.
One of my rules is to always make sure that your brain is in gear before engaging your mouth, or in your case keyboard.
Please don't make statements or accusations you cannot back up. It makes you out quite the fool.
Thank you"
Offline napaguy
« Reply #17 on: December, 11, 2010, 12:28:10 PM »
as long as they arent cast in Canada I wouldnt worry about it too much.....
Offline stangg
« Reply #18 on: December, 11, 2010, 01:36:14 PM »
Kinda throws the whole cast in China vs Australia debate out the window if they are truly cast in Australia...
Can we get back to the topic of these chinese heads that the OP got.  My original posting was simply to give the OP some guidance on what to look out for.
Online 67 Fastback
  • Bill Watson
« Reply #19 on: December, 11, 2010, 02:05:49 PM »
Paul, do you run these heads?
Bill
Offline pprince
  • 5F09C332634
« Reply #20 on: December, 11, 2010, 06:23:27 PM »
NAPAGuy, why the hell would you say something so outright childish? Grow up!
« Last Edit: December, 11, 2010, 06:35:53 PM by pprince »
Offline pprince
  • 5F09C332634
« Reply #21 on: December, 11, 2010, 06:24:40 PM »
Bill
Moneymaker head? Yes, on my 89 GT
« Last Edit: December, 11, 2010, 06:33:46 PM by pprince »
Online lethal289
  • Steel Hoods Rule!
« Reply #22 on: December, 11, 2010, 07:15:26 PM »
I thought it was funny...  Now i'll go sit in the corner and i'll  :stfu
Offline napaguy
« Reply #23 on: December, 11, 2010, 09:19:50 PM »
Lmao Paul seems to be grouchy today...grow up? Never
Rumor has it Paul works for Alex
(hope that didn't sound childish Paul)
Offline pprince
  • 5F09C332634
« Reply #24 on: December, 12, 2010, 05:23:09 AM »
lol, no I have a sense of humour :)
I heard that those who can do but those that can't work at NAPA.
 :nut :part
