My car had a really rough idle and sometimes had problems starting. Once running, exhaust smelled really rich/gassy. Found to be an ignition short and I believe I tracked it down.
The 12v wire running from the green/red ign wire to the + terminal on the coil had a loose quick splice connector.
No problem - ran a new wire with a new quick splice connector and I thought I was good.
However, upon restart, the car still has a rough/intermittent idle and seems sputtery.....albeit, much better than before.
Checked timing and we're good there. Also checked for any vacuum leaks and no leaks.
Question is, someone mentioned that the coil may be bad. How can you test it? Maybe I should check the plugs? I think this ignition short may have fouled the plugs due to poor spark.
But other than fouled plugs, how would you determine if a coil has gone bad? MSD billet ready-to-run dizzy and the Blaster 3 coil.
Thanks.
