Linux Mint 11 Rulez....
Simple question, but... was it hot and running when you checked it before you put fluid in?
Rear seal, shifter seal, lines to cooler, vacuum modulator, pan gasket.......front seal. Did you over fill it?
I think they take 9 qts. when dry. Run it and see where it is on the dipstick.
I thought you check it in park.......warm......
over fill i dont think so i put in at least 10ltrs
