Windoze 7 may not like the post box...............
And since i ordered the part over two years ago there is no way i have any come back. Thats a serious fu$k up for a $1,100 part.
I'd call Summit and explain the situation/delay. I've had them work with me in the past and their customer service is usually pretty reasonable.
i'm confused. are you trying to put in four bolts per port? aren't the extra holes simply for different bolt pattern headers/heads?
I might just take a look to see if it is possible to alter the ones I have. Is there any trick to check if the ports lines up. I was thinking about using some tracing paper and making a impression of the cylinder head ports and then another of the ports on the JBA headers then use the 2-3 holes that line you as reference points. any others ideas?
