jmbyard
rayms69
automaki
petes68pony
Author Topic: 69 heater box rebuild  (Read 288 times)
Offline DougG69
  • Cleveland Powered
« on: August, 02, 2010, 09:03:41 PM »
Does anyone know if there should be some sort of gasket/sealer between the 2 halves of the heater box in a 69?
I have pulled mine apart & cleaned, painted, glued in new foam etc., and it seems like there should probably a gasket of some type, but there wasn't one in the rebuild kit and all the foam seals were pretty much dust. I am thinking of maybe using a little 3M strip caulk. Or?
Other than that, all I need to do is test the new heater core for leaks & put it all back together  :pep
-Doug-
69 Mach 1 - 351c, TKO
Offline sigtauenus
  • Es divertido meterse con Duane
  • stirring the pot
    • Folddownseat.com
Re: 69 heater box rebuild
« Reply #1 on: August, 05, 2010, 11:48:31 AM »
I used the strip caulk for mine.  Just laid a single bead in the side that has the channel, squeeze the two sides together and then scrape off whatever squishes out from the seam.
Sam
Member number 427
68 Coupe
Offline DougG69
  • Cleveland Powered
« Reply #2 on: August, 05, 2010, 07:27:18 PM »
Cool, sounds like a plan. Thanks for the reply.
Offline miketyler
  • Antique jukebox, Cuda, Mustang restorer and all around good guy
« Reply #3 on: September, 07, 2010, 05:01:36 AM »
Yup, mine was glued with some sort of black stuff originally but was all dry and crumbly. I used strip caulk on mine as well.
Got pics of your finished box?
Offline DougG69
  • Cleveland Powered
« Reply #4 on: September, 07, 2010, 09:18:15 AM »
Unfortunately, I do not. Didn't even occur to me. I was just so glad to be done with it, all I wanted to do was get it put back in ;)
