rayms69
automaki
petes68pony
machlarson
Author Topic: Tight fit - AOD and TCP cross brace  (Read 918 times)
Offline 2ndgen
  • Loves the Sheep Organs
  • Active Poster
  • Waiting for parts...
« on: July, 24, 2010, 02:02:56 PM »
Progress on the exhaust...
Comments welcome!
-Rory
"I'm not a Mustang expert, but I play one on the VMF StangFix"
69 Mach 1 - 393W - AOD w/4R70W internals - 3500 stall - 3.70 tru-trac - PS w/o air
multi-year rotisserie restoration
It now drives!
Offline RyanG85
Re: Tight fit - AOD and TCP cross brace
« Reply #1 on: July, 24, 2010, 02:56:30 PM »
Looking good. What headers are you using? I'm on the fence on shorties or long tube for my 65 project.... Need to decide pretty soon!
Offline 2ndgen
  • Active Poster
« Reply #2 on: July, 24, 2010, 06:34:33 PM »
JBA shorties for the 351W...
Between loathing power steering drop brackets and having an AOD I did not want to fight long tubes!
I can't wait to see the system complete with the tips for the dual exhaust valence and the H-pipe. The job is taking a long time but the work is beautiful. It is really tight with the cross brace, AOD, and AOD cross member.
The basis for the exhaust is the Magnaflow kit, but it is pretty modified in the front and there was no way for the x-pipe.
Good luck,
-Rory
Offline Jonk67
  • Yak, Yak, Yak
  • Smyrna, TN
« Reply #3 on: July, 25, 2010, 09:29:31 AM »
I hope I have as much room as you when my AOD and exh. is in for good, looks like the exh. shop did a good job giving clearance, I'm sure it was tighter before they modded your kit. Too clean under there, hit the road and get some scars... :pbj
Jon
Offline buening
« Reply #4 on: July, 26, 2010, 04:49:26 AM »
I was just getting ready to say that theres no way you'd fit an Xpipe, but you figured that one out already   :craz    Looking good by the way!!!
Custom Motor Mounts
T56 Conversion
Offline daveSanborn
« Reply #5 on: July, 26, 2010, 11:13:47 AM »
Looks like a nice, clean install.  Keep an eye on the your axle vent tube and rear brake soft line for any interference issues with oyur drivers side tailpipe.  While an X pipe may be difficult, there's a perfect spot for an H pipe just aft of the transmission crossmember.
