jmbyard
rayms69
automaki
petes68pony
Author Topic: Westley's Bleech White tire cleaner on uncoated Aluminum wheels. Big NO NO!  (Read 1483 times)
Offline 68EFIvert
I have used westley's in the past to clean rubber parts like hoses and tires with great success.  I started to use some tire polish that has left a film on my tires that needs to come off before the big MCA show this weekend.  I picked up some Westley's and sprayed it on before I washed my car thinking I'll give it a little time to work.  When I got done with the body I started to wash the wheels and realized there was a few white dots and white runs.  I thought it was interesting, that is until I tried to wash it off.  The Westley's looks like it etched the wheels.  I don't think it was on there long enough to do serious damage but I will have to give them a serious scrubbing with Mothers Aluminum polish and hope for the best.
I was pretty pissed at myself not to read the label before spraying.  Right on the back highlighted by a box is do not use on magnesium, painted surfaces or aluminum because it may cause permanent damage.  I guess if there is some pretty serious damage on some of the wheels I could look into having them chromed but I really don't want to spend the money on something like that.  If the mother's doesn't work I have some Flitz that I will give a try.  :cry
Darreld
Offline johnpro
Wow, that really sucks.  I only use the Bleach white on my raised white letters, where I have them.  Scary has chromed Craiger S/S's on it, but I'll need to be careful with my daughter's car (and warn her), as she now has Radial T/A's and I believe older, unfinished aluminum wheels.
Thanks for the heads up.  I never would have thought about it.
Offline 68EFIvert
I can also give you a tip to clean it off.   :pbj  Spend 2 hours with a Mother's polishing ball with Mag/Aluminum cleaner and they will look like new.  I will likely hit them with Flitz tomorrow to finish the job.  They really don't need the extra polish but I think flitz stays polished longer and is easier to clean up than mothers.  I went through 3 batteries on my Milwaukie cordless drill.
Offline buening
That'll just make you wanna cry.  Glad the polish took it out.  While I had my valve covers off my engine, I decided to take a mothers power ball to them with some polish.  The water spots etched too far into the aluminum and it wouldn't polish out.  I may have to take some fine grit sandpaper or rubbing compound to get it out.  Sucks.
I wonder if Zoops sealer or something would be worth looking into Darreld?  Not cheap but it would hold the shine longer than a standard polish.
Custom Motor Mounts
T56 Conversion
Offline Starfury
  • My car HATES me
I'd never recommend using Bleche-white.  It has some nasty stuff in it that isn't good for anything rubber.  Most tire manufacturers recommend against it.
Tad H.
'67 fastback
331 stroker
3sp m/t
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
Bump...
anyone have experience with Bleech White and powder coated rims?
