Any of you gurus out there ever have to create a new mounting hole on your manual shifter because your new switch doesn't line up with the original mounting hole? I figured no big deal, lay it out, drill it,tap it for a 1/4 -20 and should be good to go. Yeh right. Titanium bit, low speed, a little oil..... barely even discolors it. What kind of metal is this? Any hints or insight?
Thanks
Jeff
