rayms69
automaki
petes68pony
machlarson
Author Topic: What coolant temperature for a 347 stroker?  (Read 201 times)
Offline Tims65
  • Quiet Type
« on: May, 29, 2010, 04:28:26 PM »
What should be my target engine coolant temperature for a 347 stroker?
I've got a 180* thermostat and a good electric fan. When the fan comes on it will drop the temperature 8*. I can set the electric fan to come on when ever I want.
Right now I have the fan set up to come on at 200*, once the temperature gets to 192* the fan kicks off. Is this a good range or should I raise or lower the operating temperature?
Thanks,
Tim
Offline Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
Re: What coolant temperature for a 347 stroker?
« Reply #1 on: May, 29, 2010, 04:39:25 PM »
The very original Ford thermostats were designed to open at 198*, but most people nowadays run 180* thermostats.  Sounds to me that you have good numbers right now.  So long as your engine temperature doesn't creep up, you'll be fine.
Panama City, FL
Offline johnpro
« Reply #2 on: May, 29, 2010, 07:05:08 PM »
 :wstup
Offline Tims65
  • Quiet Type
« Reply #3 on: May, 31, 2010, 05:15:55 PM »
Thanks guys, I'll leave it as set.
Tim
