I noticed a similar tendency when I put the T5 in my car. Looked like it was twisted to the right just like yours.I'll see if it's any different when it goes back in when the engine is finished.
Very cool. Dig the wooden crossmember! :lol Looks like 10lbs of crap in a 5lb bag though...looks like it's tighter than a you know what's you know what!PS: How's the weather out there? I'm set for a flying trip through Bloomington on Saturday and I dunno if I should pack my long johns. :lol
did you get a measurement of the engine angle and driveshaft angle with your drop mounts installed?
i completely disagree with your statement about the drivehaft angle being irrelevant. i could draw you a picture of an engine 3 degrees down and a pinion at zero degrees that would eat universals.i'm fine with the whole pinion angle needing to be close to equal and opposite, but you also want to minimize the working angle of your u-joint. thus you need to measure your driveshaft angle.
Loving your thread here and having done this using a kit I can really appreciate the hard work you are going through to DIY it.
Thought I'd share a bit of info on the crossmember part of my install.The supplier provided a Ron Morris Unicross crossmember.I'm not necessarily advocating it, but it did offer some advantages.I've included a couple of pics below.One neat feature was the parts that attach to the frame rails, and the side-to-side adjustment.
The main thing I wanted to point out is the way these things mount to the frame rails.I wish I had a pic showing this, but there's a plate on the outside of each frame rail with tubes that go through the inside of the frame rails. The bolts go all the way through the frame rails.This design prevents the frame rail from collapsing when the bolts are tightened.Sorry the pics suck, and good luck on the build!
