rayms69
automaki
petes68pony
machlarson
Author Topic: What PCV valve for a stroker???  (Read 414 times)
Offline 2ndgen
  • Loves the Sheep Organs
  • Active Poster
  • Waiting for parts...
« on: May, 08, 2010, 08:37:12 AM »
This is my first stroker build and I am dialing it in...
The last issue is that it seems I have too much pressure in the crankcase and my PCV valve is not up to the task.
The engine is a 393W with a fairly aggressive hydraulic roller cam. At idle it draws between 12 and 13 inches of vacuum.
I am using a new stock 351W PCV valve... I am beginning to wonder (particularly so after noting the vast difference in initial timing vs a stock engine) if I need to use a different PCV valve. Then again, I have no idea how the PCV valve part number relates to displacement or vacuum.
I realize that part of the issue may be that the rings have not fully seated yet too...
If you are running a 393 or 408 stroker, what did you do for a PCV valve?
Thanks in advance,
-Rory
"I'm not a Mustang expert, but I play one on the VMF StangFix"
69 Mach 1 - 393W - AOD w/4R70W internals - 3500 stall - 3.70 tru-trac - PS w/o air
multi-year rotisserie restoration
It now drives!
Offline Sluggo
  • How you like dat Jake?
    • www.StangFix.com
Re: What PCV valve for a stroker???
« Reply #1 on: May, 09, 2010, 04:21:48 AM »
I run a regular 351 pcv valve in my 427 stroker. Seems fine.
Offline garner67
  • Sunroof Option Expert
    • Garner67 - CarDomain
« Reply #2 on: May, 10, 2010, 11:19:55 AM »
I just ordered an Earl's performance PCV valve for my engine.
Summit Racing link
I wasn't having any blow by issues, but an open breather wouldn't pass tech inspection at my last track event.  They said that all valve cover breathers have to vent to a catch can.
« Last Edit: May, 10, 2010, 11:21:59 AM by garner67 »
Mike
Offline johnpro
« Reply #3 on: May, 10, 2010, 05:39:31 PM »
I've just been running a stock 351w PCV valve in my 408.  Never a problem with it, at all.
Offline 2ndgen
  • Active Poster
« Reply #4 on: May, 11, 2010, 09:38:48 AM »
Yet another brand new defective part:  :fbomb
At least this was just a $2.99 fix.
-Rory
