Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Home
Help
Login
Register
StangFix.com Forums
Forum
1964 1/2 through 1973 Mustang Boards
Engine and Drivetrain Board
Is the pertronix II or III worth it?
Random Image from the Gallery
Latest Victims
rayms69
automaki
petes68pony
machlarson
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Is the pertronix II or III worth it? (Read 294 times)
panteramatt
Active Poster
on:
April, 09, 2010, 12:21:38 PM »
Im putting a pertronix unit in my 69 with an msd blaster 2 coil. Are the II and III worth the extra $? Do they offer a lot more spark? Not sure If I need the rev limiter since I have an auto.
Logged
AzPete
Classic...less
Global Moderator
Shutup Already
Re: Is the pertronix II or III worth it?
Reply #1 on:
April, 09, 2010, 12:32:06 PM »
The Pertronix 1 has always been real good for me.
Logged
USAF/Ret.
7 Previously owned..66-07
panteramatt
Active Poster
Reply #2 on:
April, 09, 2010, 01:07:59 PM »
Ok, well I went with the III. For the little extra $ I thought it was worth it and I got it for $105. So I have another question. I see that the stock points system has 1 wire going to the coil, and the coil has another wire going to a harness in the firewall. The instructions I read say the ignitor has 2 wires coming from it, both go to the coil. I will be using a msd coil. Do I just hook up the neg from the ignitor to the neg on the coil and then the pos to the coil and use the other wire from the firewall on the positive side of the coil?
Logged
johnpro
Talks Too Much
Reply #3 on:
April, 09, 2010, 08:00:26 PM »
Check with Pertronix to see if that coil is compatible. If it's not, you'll need to run a ballast resistor between, or you'll fry the Pertronix in about 10 minutes ... been there, done that, got the t-shirt.
Logged
Print
Pages: [
1
Go Up
« previous
next »
StangFix.com Forums
Forum
Powered by
EzPortal
