Find a local shop with a water jet....
One challenge will be cutting out this steel plate. I don't have a steel bandsaw, so it'll either be a cutoff wheel and grinder for the rounded corners or a jigsaw with a metal blade. The jigsaw may take years and go through a ton of blades, so I'll try the cutoff wheel. Sucks not having the right tools....and no I'm not buying a bandsaw!
A waterjet would be great but if for a DIY the a good jig saw / sabre saw and metal cutting blades is all that you'll need. So long as you use low / medium speed you won't be wearing out blades.I've got bosch saw and use thier T118A blades and have cut a lot of 1/8" to 3/8" plate. http://www.amazon.com/Bosch-T118A-3-Inch-24-Tooth-Blades/dp/B0000223FY
Nice work.Question if you don't mind. How is the midplate attached to the bushing housing? Obviously welded. I'm just wondering if you plan a gusset or two there. Looks like it could be a weak point.
Looking good.Have you put any thought into up and down adjustments? If you built them as low as possible, you could use spacer plates between the motor bracket and the bushing bracket for height adjustment...
That looks really good Jeremy! I am glad they worked out good so far. Are you making these with a 1" drop or standard height?Can't wait to see the finished product.
Thanks! I will be detailing different shock tower brackets that will each lower the motor 1/4" at a time. I'm shooting for only 1/2"-3/4" drop in order to get the proper driveline angle. While your idea would work, you are essentially making the moment arm larger by using spacers and that location is IMO the weakest spot of the mount. I could be wrong though. The reason my triangular piece is so short is because I was trying to minimize the height of the intermediate "T" section, which also minimizes the distance from the motor to the bushing bolt.
