StangFix.com Forums
July, 30, 2010, 06:45:22 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length  Or  Connect with Facebook
News: PBJ New Look...Same great taste! PBJ
  Home   Forum   Chat() Help Shop SMFbuy Login Register
collapse
* Random Image from the Gallery.
By: daveSanborn
* Latest Victims
* Calendar Events
* Top Posters
silverblueBP silverblueBP
Fast68back Fast68back
lethal289 lethal289
70_Fastback 70_Fastback
AzPete AzPete
* Top Boards
Pages: [1]   Go Down
  Print
Share this topic on FacebookShare this topic on Del.icio.usShare this topic on DiggShare this topic on StumbleUponShare this topic on Twitter Topic: Watts Link vs. Panhard (for my Ratrod coilover/4-link rear setup)  (Read 173 times)
0 Members and 1 Guest are viewing this topic.
70_FastbackTopic starter
I ate granny's prawn.
Super Moderator
Yak, Yak, Yak
Hell Bent for Speed
Offline Offline
Abducted:August, 07, 2008, 12:25:15 PM
1002205.50 credits
View Inventory
Send Money to 70_Fastback
facebook
« on: March, 04, 2010, 07:22:35 AM »
ReplyReply
I'm thinking of fabricating a Watts Link for my 4-link/coil over rear in lieu of a panhard bar for the ratrod rear end setup.
http://www.mindlissmetal.com/wp-content/gallery/watts-links/p1010005.jpg
(Something similiar too this)
http://www.gripping.dk/img/t_anim_w2.gif
What are some Pros & Cons of doing this Vs. a panhard bar for my particular application?  Which is not really a "performance" based vehicle.  I think this would eliminate the slight sweeping 'arc' from a single sided panhard bar installation.  But is that the only real difference?
Discuss.
Thanks.
Logged
1970 Grabber Fastback
tarafied1
второй craig
Contributor
Valued Member
January 09 Car of the month Winner!!!
Offline Offline
Abducted:September, 10, 2008, 06:15:24 PM
1047783.25 credits
View Inventory
Send Money to tarafied1
WWW facebook
« Reply #1 on: March, 04, 2010, 03:54:50 PM »
ReplyReply
I have no expertise to offer but I do think it would look cool!
Logged
Married to TARA, that makes me the TARA-fied 1!
Proud user of ORP Roller Perches!
MCA member 71082
I want to leave this world like I came in, by accident!
stangg
Quiet Type
Offline Offline
Abducted:January, 03, 2009, 07:28:47 PM
818.00 credits
View Inventory
Send Money to stangg
« Reply #2 on: March, 04, 2010, 05:19:12 PM »
ReplyReply
I'm building a watts link for my '65 El Camino.   I think it looks cooler than a panhard bar, plus I like that of all the systems it minmizes side movement the most.
On mine the swivel arm / propeller is mounted to the frame as opposed to the rear end.   I'm not absolutely certain which version is better, but I think the frame mount swivel is better because the roll center stays consistent with the body/chassis and not the axle.  Fays and Steeda both use the frame mount pivot method.
My main reason for the frame mount pivot is that I didn't want to build extensions off of the frame for fear of adding too much torsional stress to the frame,  and I also wanted to keep the links short to keep the packaging pretty tight to allow plenty of room for the exhaust.
The frame mount is done in the second picture,  for the axle mounts I'm probably going to make permanant mounts so I'll need to wait until I can build the 12 bolt rear end.  For mockup on the 10 bolt I just welded some tubes / nuts to the axle tube.
For the swivel arm,  I'm hoping my son can CNC mill out an aluminum piece before he finishes high school this year... If not, I may just cut my own pieces and fab it out of three pieces up like shown in your picture. My first attempt failed since the holes weren't exactly equi-distant.  These holes need to be precising cut. Someone with a waterjet or laser jet could cut them too.  For the center pivot I might use an small wheel hub with bearings and a center spacer.  The other thought I had was to use the roller skate bearings used on roller perches. The $10 links are from speedway motors, and I already had the hiems.
If you build your own,  there is a company in street rodder magazine that sells the urethane bushings and adjustable end links.  I'm not sure but I think they sell the DOM tubing too.
http://home.comcast.net/~stangg/elcamino/watts1.jpg
http://home.comcast.net/~stangg/elcamino/watts2.jpg
Anyway,  my vote is for the watts.
Logged
Super Moderator
Yak, Yak, Yak
Hell Bent for Speed
Offline Offline
1002205.50 credits
View Inventory
facebook
« Reply #3 on: March, 05, 2010, 05:49:33 AM »
ReplyReply
The dudes on the RatRod forum are recommending just a triangulted 4-link setup and ditch the Watts & Panhard.  I like the looks of the Watts though. I think a person could get really creative in the fabrication of the brackets and locations.
Logged
daveSanborn
not Cha Cha Muldowney
Founding Father
Yak, Yak, Yak
Not your average computer genius!
Offline Offline
Abducted:August, 04, 2008, 06:43:29 AM
Awards:
Friend O'the Leprechauns!
31829.25 credits
View Inventory
Send Money to daveSanborn
« Reply #4 on: March, 06, 2010, 05:50:44 PM »
ReplyReply
I'm using a panhard bar.  When adjusted properly, the side to side movement is negligible... maybe 0.5".
While I like the Watts link design, I think it'll cause issues with the coilover mounting locations.  For instance.... look at your (really cool BTW) animated graphic of the Watts link in operation....  where/how would you mount the coilover springs so as not to interfere with the operation if the links?
The Watts link would be more fun, but the simple Panhard bar will get the job done just fine.
Logged
Super Moderator
Yak, Yak, Yak
Hell Bent for Speed
Offline Offline
1002205.50 credits
View Inventory
facebook
« Reply #5 on: March, 08, 2010, 06:10:23 AM »
ReplyReply
Hi Dave.  That is a good point, but would think as far as location of the coilovers;  they would have to be located on the front side of the axle tubes.  And maybe (though I don't care for the look much) fabricate an elipticle bracket (like in the picture above) to move the Links further behind the axle.
I've have material to try both ways, so I think I'll just play with it and see which one I like better.
Logged
stangg
Quiet Type
Offline Offline
818.00 credits
View Inventory
« Reply #6 on: March, 08, 2010, 08:40:54 AM »
ReplyReply
If you go with a 3 or 4 link then I think you'll want to mount your coil overs on the rear of the axle tubes... this will essentially preload the axle and lessen the chance of wheel hop under hard accelleration.  Also,  mount them as far outboard as possible for more precise handling / tuning.  On the watts link, I don't think longer links are nesseacary like on a panhard bar.
Logged
Super Moderator
Yak, Yak, Yak
Hell Bent for Speed
Offline Offline
1002205.50 credits
View Inventory
facebook
« Reply #7 on: March, 08, 2010, 08:43:21 AM »
ReplyReply
Makes sense.  So basically reverse my previous statement.
And is there a "better" angle for the coilove shocks - in/out?  Or just straight up and down?
Logged
gt289
Found it!
Offline Offline
Abducted:February, 26, 2010, 03:24:55 PM
328.50 credits
View Inventory
Send Money to gt289
« Reply #8 on: March, 08, 2010, 08:43:57 AM »
ReplyReply
The Watts is the best means of axle lateral control. It is also the most difficult to do, in terms
of engineering. Even a carefully thought out panhard bar usually introduces some unwanted
geometry when the rear axle goes through its movements.
Logged
Pages: [1]   Go Up
  Print
Jump to:
StangFix Member Approved Vendors
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SimplePortal 2.3.1 © 2008-2009, SimplePortal
Valid XHTML 1.0! Valid CSS!
Page created in 0.936 seconds with 37 queries.
