rayms69
automaki
petes68pony
machlarson
Author Topic: 70 Mach 1- How wide can you go?  (Read 4889 times)
Offline miketyler
  • Antique jukebox, Cuda, Mustang restorer and all around good guy
« on: March, 04, 2010, 03:42:51 AM »
I have 315/35-17's on the back of my 72 Cuda and 275/40-17's on front. The wheels are TT2's and are actualy Mustang fitment.  How can I get that size wheel and tire under my 70 Mach1? To pull off the clearance on the rear of the Cuda, I had to install a rear spring relocation kit that moved the leaf springs in 1.5 inches.
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
Re: 70 Mach 1- How wide can you go?
« Reply #1 on: March, 04, 2010, 07:31:41 AM »
Interior mini-tubs and fender lip rolling would prbably be required.  You may be able to just move the inner wheel house in a few inches and section in a strip of metal to fill that gap between inner and outer houses as well.  Either way, you have a little work involved.
My stats:
Fronts are 245/40/17 (8" rim)
Rears  are 275/40/17 (9" rim with 6" backspace)  I later added a 3/8" spacer.
Offline 68EFIvert
« Reply #2 on: March, 04, 2010, 12:57:33 PM »
If the wheels are Mustang fitment why not take them off the Cuda and put them on the Mustang.  I would love to see some pictures of where you may have clearance problems and it would give all of us a visual of what mods to make.
Darreld
Offline Grabber70Mach
  • Yak, Yak, Yak
« Reply #3 on: March, 04, 2010, 06:31:18 PM »
315/35/17's
Offline miketyler
« Reply #4 on: March, 05, 2010, 06:14:45 AM »
Thats EXACTLY what I am talking about. Look like you are running Sumitomo's like I have on the Cuda. The rears on the Cuda are TT2's and are 11" wide rims w/ 7" backspacing (I think).  Is that what you are running? What did you have to do to get there? Any suspension mods or sheetmetal wizardry?  Do you have any more profile pics of your car? Some of 15-20 ft away?
« Last Edit: March, 05, 2010, 06:33:23 AM by miketyler »
  • Yak, Yak, Yak
« Reply #5 on: March, 05, 2010, 05:59:30 PM »
Thanks, here are the specs for my setup.
Front:
Style: Bullitt Finish: Anthracite
Size: 17x8 Centercap Size: Large (2-1/2")
Back Spacing: 5.72" (145mm) Offset: +30mm (1.18")
Bolt Pattern: 5x4.5" (5x114.3mm) Fitment: 94-09 V6, GT, Bullitt,
Mach 1, and Cobra.
Tires are Sumitomo 245/45/17
Rear:
Size: 17x10.5 Centercap Size: Large (2-1/2")
Back Spacing: 6.8" (174mm) Offset: +28mm (1.10")
Bolt Pattern: 5x4.5" (5x114.3mm) Fitment: 94-04 V6, GT, Bullitt,
Mach 1, and 94-98 Cobra
Tires are Sumitomo 315/35/17
I am using the Vintage Venom Cobra brake kit, it uses a
1" hubcentric spacer in the front and a 7/16" in the rear.
I did do the 1" Shelby drop in the front. I did have to massage the front of the rear inner fender wells. I do intend to roll all the fender lips just for piece of mind.  Removed the slapper bars and have installed 5 leaf Mid-eye springs since these pics.  Also have a Maiers racing adjustable panhard bar to install when I get the chance.
This is how its sitting now w/ the new rear springs, I have thought about getting the rear a little lower though but still not sure.
« Last Edit: March, 05, 2010, 06:13:07 PM by Grabber70Mach »
Offline 70_Fastback
« Reply #6 on: March, 08, 2010, 08:47:41 AM »
I couldn't go wider because I'm lowered & my wheels are set up in my wheel wells.  I'm close to the wheel well lip as it is.
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #7 on: March, 08, 2010, 06:21:29 PM »
man those 70's look good guys!
Thanks Sam
  • Yak, Yak, Yak
« Reply #8 on: March, 09, 2010, 06:34:19 PM »
Thanks, but it still needs a lot of work.
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #9 on: March, 09, 2010, 07:32:27 PM »
maybe so but you're making me want one!
Offline buening
« Reply #10 on: March, 10, 2010, 09:51:37 AM »
Jeremy,
How much clearance do you have between the rear quarter lip and the tires?   Its crazy that one guy can fit a 315 tire with 10.5" rim and you could only go 275 with a 9" rim.  You are lowered which plays a part, but do you have a few inch clearance at the quarter lip?  It appears you two have similar clearance between the leaf springs.
Custom Motor Mounts
T56 Conversion
Offline 70_Fastback
« Reply #11 on: March, 10, 2010, 11:08:06 AM »
My lip is not rolled.  And as it sits, I can barely squeeze my fingers between the tire and lip at an angle.
In other words, it's really close. But with full suspension travel the tire cleares the wheel well lip.
Barely.
Offline buening
« Reply #12 on: March, 10, 2010, 01:25:10 PM »
So where the heck is the rest of the 1.5" of rim fitting on the grabber blue mach?   This is weird, something doesn't add up.
Offline 70_Fastback
« Reply #13 on: March, 10, 2010, 01:43:50 PM »
It sure looks to me that his wheel sticks out past the top of the wheel well lip to me.  My tire is actually up inside, where his looks to not be.
I think that is the difference.  Maybe?
Offline Fast68back
« Reply #14 on: March, 10, 2010, 01:58:06 PM »
Hard to tell
Offline 70_Fastback
« Reply #15 on: March, 10, 2010, 01:59:22 PM »
I agree.  I just know that there is no way that I could go wider - outwards, without rubbing.
  • Yak, Yak, Yak
« Reply #16 on: March, 10, 2010, 02:41:26 PM »
Ran out to the shop and took some photos, hope this shows what is needed
Rick Flores also runs a simular setup on a 69 Mach
http://www.popularhotrodding.com/features/0308phr_1969_boss_ford_mustang_302/index.html
« Last Edit: March, 10, 2010, 02:43:17 PM by Grabber70Mach »
Offline Fast68back
« Reply #17 on: March, 10, 2010, 02:46:00 PM »
Nice Car, and its in Texas!
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #18 on: March, 10, 2010, 05:14:41 PM »
oh now that does it, you guys are killing me. Now I HAVE to HAVE a 69/70!
Offline RyanG85
« Reply #19 on: March, 10, 2010, 06:13:13 PM »
WOW, that 69 is BADASS!
Offline buening
« Reply #20 on: March, 10, 2010, 07:00:12 PM »
Rick must have mini-tubs in his car based on the 17x11 rims and the clearance between the wheel lip and the tire.  True?
Ted, unless the angle of the pic magnifies it, it appears your rim is pretty darn close to the wheel lip.  Lowering your car would definitely require a rolled lip.
Offline SELLERSRODSHOP
  • Nick Jr.
  • I smell smoke....
« Reply #21 on: March, 10, 2010, 10:40:57 PM »
here's some good info for 69-70 on 69stang. also a few pics of some other cars in flores' shop. some of the nicest i've seen...
http://www.1969stang.com/mustang/forum/showthread.php?t=2248
"I love this country, it's the government I'm afraid of"
  • Yak, Yak, Yak
« Reply #22 on: March, 11, 2010, 06:53:38 PM »
IIRC when I talked to him about his setup it was a stock suspension/setup with the fenders rolled.
I do plan on rolling the fenders and have thought about lowering the rear a little more.  Just not sure if I should lower it or leave it as it sits.
Offline miketyler
« Reply #23 on: March, 14, 2010, 05:40:42 AM »
That 69 is the look I am after, very similar to the lowered fat stance on my Cuda. Is Rick running 275/315 combo front and rear? Are those 17's he has on there?
Offline buening
« Reply #24 on: March, 15, 2010, 06:20:32 AM »
Man thats one heckuva good looking Cuda you have there Mike!  Cudas and Challengers are my second love next to Machs.  I could buy a restored mach for the price of a rusty Cuda though  :sad
Have you tried your Cuda wheels on your mustang? IIRC they have the same bolt pattern.
