machlarson
palerider
PONY75
Phils69
Author Topic: noisy gear drive any advice pros and cons  (Read 1185 times)
Offline GT350
  • mustang_aholic there is no cure
    • classic mustangs uk
« on: March, 03, 2010, 01:32:35 PM »
below is  a vid of my actual car with 351w fitted with a geardrive,what are the pros and cons of having this noisy set up in car ?
http://www.youtube.com/user/UKMILITANTZ#p/a/u/1/b0Sw1yMROpg
http://www.classic-mustang.co.uk/index.php
[img width=400 height=29]http://img.photobucket.com/albums/v403/b
Offline Fast68back
Re: noisy gear drive any advice pros and cons
« Reply #1 on: March, 03, 2010, 01:47:53 PM »
Ask Jeremy....  :dh
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
« Reply #2 on: March, 03, 2010, 02:38:00 PM »
Con #1:
Con #2:
Con #3:
Con #4:
Pro #1 (for her, not me):
Any questions?
Offline 70_Fastback
« Reply #3 on: March, 03, 2010, 02:40:05 PM »
Here was my gear drive:
Went back with the same cam again after the breakage.
Offline 66gt350
  • Ah like me sum gunz...
« Reply #4 on: March, 03, 2010, 03:03:49 PM »
I was running one in the 351W I used down at the track, and was turning in 12.5's in the quarter...I was shifting at around 7500 rpms.  I never had any problem with it, but I did bust a skirt off a piston, but that's a whole 'nother story.  IIRC, the one that I have is an Edelbrock.  I was noisy.  I couldn't sneak up on anyone with it.
Jeremy...what in the world were you doing to break one?  They're meant to take abuse and keep the timing exact, and not stretch like a chain.  I hate to ask, but are you sure that you had it installed properly?  I had to do some grinding on the inside of my TC cover to get it to fit correctly.
-rob "Ricky Bobby"
No one is listening to you until you fart.
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #5 on: March, 03, 2010, 06:49:12 PM »
he was blowing the doors off a PT Cruiser!!! you should have been there!
Thanks Sam
Offline silverblueBP
    • My 66 2+2
« Reply #6 on: March, 03, 2010, 07:10:47 PM »
IIRC, he was on a slow leisurely cruise to get ice cream at the last CornFeed.
How ghey is that?
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #7 on: March, 03, 2010, 09:03:30 PM »
okay, ya got me. But my version sounds better!
Offline 70_Fastback
« Reply #8 on: March, 04, 2010, 07:12:57 AM »
As Mark stated... We were on a highway cruise to Baskin Robins to get 1 percentage of the 31 flavors.  And while cruising at highway speed the car just up and shut off.  No jerks, bangs, pops or anything.  I thought I had maybe ran out of gas and that my gas guage was not working.  I coasted it to the side of the road and tried restarting.  The engine whirled over WAY to easy.
I would ascertain that it was installed correctly.  I clearanged the timing chain cover as you did to clear the gear drive.  The gear drive was the Edelbrock Accu-Drive Gear Drive.  I called Edelbrock to complain, etc - and they actually told me they don't "recommend" those drives for SBF engines.  But they are great for Chevys...  go figure.  They also told me the gear drives are manufactured by Cloyes.
This appears to be what started the failuer; a broken snap ring that retained the dogbone idler gear:
Once that was broke, the idler just started to "Walk" apart in my opinion, thus losing alignment and letting it start shredding teeth.
Offline twinturbo
  • Found it!
« Reply #9 on: March, 04, 2010, 07:52:04 AM »
I installed on on my engine Oh Shart!
[gmod]Try to limit profanity to the password boards Chuck - thanks.[/gmod]
« Last Edit: March, 04, 2010, 08:07:30 AM by 70_Fastback »
Offline 66gt350
« Reply #10 on: March, 04, 2010, 07:56:36 AM »
...and they actually told me they don't "recommend" those drives for SBF engines.
WTF...Then why the  :fbomb do they put their name on them and sell them!!  I'm glad that I didn't install it on my 5.0 motor, when I busted the piston skirt and yanked out the 351W...
Offline 70_Fastback
« Reply #11 on: March, 04, 2010, 08:08:54 AM »
I don't know.  I loved the gear drive whine.
But once bitten, twic shy...   :scar
Offline buckeyedemon
  • Quiet Type
« Reply #12 on: March, 08, 2010, 06:28:23 PM »
i have read repeatedly that gear drives have only one plus (noise if you like that) and everything else about them is bad.  the main bad thing about gear drives is the transfer of harmonics to the valvetrain.
i have no personal experience, just what i've read.
