jmbyard
rayms69
automaki
petes68pony
Author Topic: 302 auto vs standard  (Read 361 times)
Offline Rob Z
  • Quiet Type
« on: March, 02, 2010, 06:32:02 PM »
I have two Mustangs. Both with 302s. The '69 has a C4 and the 70 has a 3speed.
The 69 engine is near a rebuild. Just getting a tad smokey. The engine is already out of the 70 and rebuilt. My thought is to pull the 69 engine and install the 70 rebuilt engine in the 69. Then I can take my time rebuilding the 69 to put in the 70. Confused yet  :craz
These are daily divers. Nothing special and will not end in a show or ever be worth a lot of $$.
Question - Is there a difference between the cranks which would hinder this swap? Or anything else I'll have an issue with??
Thanks
Offline johnpro
Re: 302 auto vs standard
« Reply #1 on: March, 02, 2010, 07:37:40 PM »
The difference will all be bolt-on options, with a very possible exception of the heads.  The '70's most likely have positive stop rockers, and the '69 likely will be fully adjustable.
Offline gwstang
« Reply #2 on: March, 03, 2010, 07:32:20 AM »
Find a 5.0 roller block, much nicer in the long run.  Most only need a good honing and re-ring with cam bearings and freeze plugs to be ready to go.   :amaz
Timid men prefer the calm of despotism t
Offline Rob Z
  • Quiet Type
« Reply #3 on: March, 03, 2010, 11:07:56 AM »
Find a 5.0 roller block, much nicer in the long run.     :amaz
OK, I've seen this reference but lost in actual info. Please define a 5.0 roller block????  :craz
Did it have a roller cam, rockers etc?? What years and or cast numbers.
Thanks
Offline 66gt350
  • Ah like me sum gunz...
« Reply #4 on: March, 03, 2010, 01:03:28 PM »
A roller block is referring to a roller cam.  IIRC, it was the mid 80's that ford swapped over to it.  The only issue you would have is putting it in a vehicle with a manual tranny.  They don't have the threaded hole on the side for the Z-bar.  The fox body mustangs use a cable for the clutch.
-rob "Ricky Bobby"
No one is listening to you until you fart.
Offline Rob Z
  • Quiet Type
« Reply #5 on: March, 04, 2010, 06:40:12 PM »
So what would be involved in changing to a cable? Is it simply going to a cable or a bunch of fab work? This is my first standard car so that part I'm learning as I go.
Offline 66gt350
« Reply #6 on: March, 04, 2010, 10:24:22 PM »
I can't help you out with the cable conversion.  I'm running a McLeod hydraulic throwout bearing.  But there's gotta be several people here who are running a cable.
Offline daveSanborn
« Reply #7 on: March, 06, 2010, 05:15:47 PM »
One modification normally leads to another and this is a prime example.
Without the Z-bar mounting location on a roller block, yes, swapping to either a cable or hydraulic clutch mechanism is an option.
Using a cable operated clutch has more drawbacks.  You'll likely have interference issues with the cable running too close to your exhaust manifolds/headers.  Your pedal assembly will need to be modified to mount the cable.
The hydraulic mechanism has no issues other than cost.
If it were me.... I'd focus on just swapping the two engines that you already have.  As previously stated, the largest issue you're likely to encounter would be the hassle of swapping all of the front of engine bracketry, but this is usually just a matter of getting all of the brackets lined up the way they need to be.
Offline Rob Z
  • Quiet Type
« Reply #8 on: March, 06, 2010, 11:31:09 PM »
I think Dave is reading my mind. Althought the roller sounds good I think just the engine swap is my best course. As I plan on taking everything off the 69 engine and placing it on the 70 engine all should ne good.
Thanks to everyone for their thoughts and help.
Planning the wap for 3 weekends from now... I think  :amaz
Offline whisperer
  • Quiet Type
  • The T-Lock Guy
    • Vintage Automotive Products
« Reply #9 on: March, 07, 2010, 07:33:07 AM »
Be aware that the motor from the automatic car will need to have a pilot shaft bushing installed in the rear of the crank, and the manual motor will need to have the same removed to fit the torque converter to it. Both the 69 and 70 cranks will be drilled for this from the factory. Other then that it is a bolt-in as long as you are using all the outboard parts from the correct car.
