July, 30, 2010, 06:40:03 PM
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Or
News
New Look...Same great taste!
Home
Forum
Chat(
Help
Shop
SMFbuy
Login
Register
0
Random Image from the Gallery.
Dash
By:
RustyRed
Latest Victims
BlueGoose
- 30 Jul
6must6
- 29 Jul
Forden1
- 29 Jul
fstrbby
- 28 Jul
mach1don
- 27 Jul
Calendar Events
Birthdays
rmarks (48)
Upcoming Events
Hot August Nights - Reno, NV
- 01 Aug
Top Posters
silverblueBP
Fast68back
lethal289
70_Fastback
AzPete
Top Boards
Gum Flapper's Lounge
Topics: 2285 | Posts: 28909
General Mustang Discussion
Topics: 1657 | Posts: 25261
Engine and Drivetrain Board
Topics: 441 | Posts: 5747
Paint & Body
Topics: 207 | Posts: 2540
Who's Online
Guests: 14
Hidden: 0
Users: 19
Users Online:
AzPete
Gigantopithecus
Kats66Pny
AtlantaSteve
6t6red
Starfury
d_ford
Mach1ne
KBMWRS
guruatbol
SAC69
RapidRabbit
sigtauenus
Jonk67
gotstang
67fastback
miketyler
stangg
StangFix.com Forums
1964 1/2 through 1973 Mustang Boards
Suspension/Brakes
> Topic:
1" height difference between left and right front - What gives??
Pages: [
1
Go Down
« previous
next »
Print
Topic: 1" height difference between left and right front - What gives?? (Read 229 times)
0 Members and 1 Guest are viewing this topic.
Indycanard
Quiet Type
Not quite done, but close (Sept 09)
Offline
Abducted:October, 15, 2009, 07:24:30 AM
477.75 credits
View Inventory
Send Money to Indycanard
on:
March, 02, 2010, 04:22:54 PM »
Reply
Standing back and looking at the front end of my 65 Conv today, it seemed like the front left and right sides were not level. I measured and my left side is 23" to the wheel arch opening and 24" on the right side. ALL components are new, upper control arm, lower arms, GT springs shocks. Within the last 30 miles (6 months
) I had the front end aligned and all checked great. I made sure the ground was level, and measured both after rolling fwd and back (to make sure toe in would not effect measurements.).
I don't want to break into the suspension since I just got an alignment, but is there a component(s) that is usually suspect. I'm thinking springs are not matched in stiffness, even though I bought them together.
Shouldn't the alignment shop have noticed?
Thanks for the help.
Logged
Henry
Before (Sept 08)
After (July 09) - But not quite done...
AzPete
Wattles when he walks.
Shutup Already
Online
Abducted:August, 08, 2008, 01:47:02 PM
49402.75 credits
View Inventory
Send Money to AzPete
Re: 1" height difference between left and right front - What gives??
Reply #1 on:
March, 02, 2010, 04:34:03 PM »
Reply
You must consider all four corners of the suspension. If a rear spring is weak, it will effect the opposite front corner.
Also, if you torqued things down with anything not on the ground, that can change things too.
Logged
AzPete
USAF/Ret.
Indycanard
Quiet Type
Offline
477.75 credits
View Inventory
Reply #2 on:
March, 02, 2010, 04:42:15 PM »
Reply
AzPete,
Thanks for the quick response,
Both Coils and both Leaf springs are new. Specifically what items should I loosen and re-tighten on the ground as a precaution.
I assume the fwd end of the leafs, I have roller perches up front.
Logged
lethal289
Guardian of Names
Yak, Yak, Yak
Steel Hoods Rule!
Offline
Abducted:June, 14, 2009, 04:51:18 PM
9999997.99 credits
View Inventory
Send Money to lethal289
Reply #3 on:
March, 02, 2010, 04:42:59 PM »
Reply
Just a thought, but do you have one stock fender and one Reproduction unit? I noticed that repo fenders i was going to use on my car, the wheel arch was higher. One of the many reasons i fixed the originals.
Logged
AzPete
Shutup Already
Online
49402.75 credits
View Inventory
Reply #4 on:
March, 02, 2010, 05:00:37 PM »
Reply
I have always been told to torque all suspension parts with the weight of the car on them, front and rear. That is a good point on the repo fenders also.
Logged
lethal289
Guardian of Names
Yak, Yak, Yak
Steel Hoods Rule!
Offline
9999997.99 credits
View Inventory
Reply #5 on:
March, 02, 2010, 05:17:56 PM »
Reply
Besides the wheel arch, measure something else like the corners of the front frame rail. See if its structurally level, and maybe your problem is just cosmetic.
Logged
Indycanard
Quiet Type
Offline
477.75 credits
View Inventory
Reply #6 on:
March, 02, 2010, 05:55:49 PM »
Reply
Thankfully I have no reproduction sheetmetal, although neither fender is original to this car. Visually the front end looks off. I will measure the frame tomorrow. On Saturday I will loosen up the suspension and see if things get better. I only have 75 miles on the suspension so far.
Last Edit: March, 02, 2010, 07:10:36 PM by Indycanard, Reason: typo..
Logged
Midlife
Intermittent Short
Founding Father
Valued Member
DOM
Offline
Abducted:August, 05, 2008, 12:10:20 AM
Awards:
48009.25 credits
View Inventory
Send Money to Midlife
Reply #7 on:
March, 02, 2010, 06:21:12 PM »
Reply
Quote from: AzPete on March, 02, 2010, 05:00:37 PM
It's better to drive 3-4 miles with slightly undertorqued suspension to allow it to settle, then torque the LCA and forward rear spring eye bolts with the full weight of the car on wheels.
Logged
Panama City, FL
lethal289
Guardian of Names
Yak, Yak, Yak
Steel Hoods Rule!
Offline
9999997.99 credits
View Inventory
Reply #8 on:
March, 02, 2010, 06:24:08 PM »
Reply
Quote from: Midlife on March, 02, 2010, 06:21:12 PM
Wouldnt this require another front end alignment once the car settles? Assuming of course that is the issue.
Logged
Midlife
Intermittent Short
Founding Father
Valued Member
DOM
Offline
Awards:
48009.25 credits
View Inventory
Reply #9 on:
March, 02, 2010, 06:29:43 PM »
Reply
Yes. That's why an alignment is about the last thing to do when setting the suspension.
Logged
Indycanard
Quiet Type
Offline
477.75 credits
View Inventory
Reply #10 on:
March, 02, 2010, 07:13:38 PM »
Reply
I'll let the suspension "settle" for 30-40 miles this weekend and check again. I have no issue having to get the alignment rechecked if indeed things even out. I would have thought if this turns out being the problem the alignment shop would have caught the 1" difference in height during the original check.
Logged
AzPete
Shutup Already
Online
49402.75 credits
View Inventory
Reply #11 on:
March, 02, 2010, 07:16:42 PM »
Reply
Alignment shops most likely don't look at the ride level. Just put the equipment on the car, align it, send it out the door. Nothing says the body has to sit straight for the wheels to be straight.
Logged
PraireBronze
Found it!
Offline
Abducted:December, 31, 2009, 08:52:02 PM
20.00 credits
View Inventory
Send Money to PraireBronze
Reply #12 on:
March, 02, 2010, 08:48:10 PM »
Reply
If nothing else helps, try swapping springs side to side and see what happens.
Logged
1965 Prairie Bronze 2+2
289 4V Automatic Transmission (A-code clone)
Black Std Interior
AC, PS, Style Steels, 1" Drop, Konis
Aluminized 2 1/4 Exhaust, Tri-Ys
FordDude
Kallipygos erastís
Valued Member
They suspended ME, but they won't trade ME. Right?
Offline
Abducted:July, 12, 2009, 05:47:52 AM
Awards:
7983468.50 credits
View Inventory
Send Money to FordDude
Reply #13 on:
March, 02, 2010, 09:36:29 PM »
Reply
I like PraireBronze response and that is what I would try first as much of a pain in the arse as that would be. Compare both front springs once they are out. If that fails you could have my SWMBO and just let her sit in the passenger seat all of the time.
Logged
Why is it that those who drive slower than you are idiots and those that drive faster are maniacs?
George Carlin
SELLERSRODSHOP
Nick Jr.
Active Poster
Offline
Abducted:January, 09, 2010, 02:19:25 PM
Awards:
7232.50 credits
View Inventory
Send Money to SELLERSRODSHOP
Reply #14 on:
March, 03, 2010, 12:16:10 AM »
Reply
if yours is like mine, she wouldn't need to sit in it. mine knows it all anyway, so could just tell him whats wrong with the car.... sight unseen
naw, actually i got a good one this time, think i'll keep her
Logged
A penny saved is a government oversight.
daveSanborn
not Cha Cha Muldowney
Founding Father
Yak, Yak, Yak
Not your average computer genius!
Offline
Abducted:August, 04, 2008, 06:43:29 AM
Awards:
31829.25 credits
View Inventory
Send Money to daveSanborn
Reply #15 on:
March, 06, 2010, 06:06:00 PM »
Reply
I know this may sound like a silly/stupid question, but are your front springs installed properly?
You definitely wouldn't be the first person to install them incorrectly.
With roller perches it supposedly doesn't matter (just learned this recently) whether the bottom of the spring terminates inboard or outboard, but are both of yours installed the same way.... both inboard/both outboard?
It gets worse..... sorry.... are you sure your springs aren't upside down? Yes, it's been done before.
It's always better to check for the easy stuff.
Logged
Indycanard
Quiet Type
Offline
477.75 credits
View Inventory
Reply #16 on:
March, 06, 2010, 07:58:04 PM »
Reply
Quote from: daveSanborn on March, 06, 2010, 06:06:00 PM
I'll check the springs. I do recall making sure each spring is butted up against the "tab" on the perch. I have the plastic isolator on the top of both. I could swear the front end looked "normal" 6 months ago.
I had to work 15 hours at work today, so first thing tomorrow I will be checking the whole front end.
Logged
Pages: [
1
Go Up
Print
StangFix.com Forums
Suspension/Brakes
> Topic:
« previous
next »
Jump to:
Please select a destination:
Events
=> Events
NewB Introductions and tutorials
=> NewB Introductions
Monthly News/Contests
=> Tutorials
=> Contests
=> Car of the Month
=> General Mustang Discussion
=> Vendor Evaluation Board
=> Engine and Drivetrain Board
=> Exhaust
=> Heating / Cooling
=> Suspension/Brakes
=> Electrical Board
=> Wheel and Tire Board
=> Paint & Body
=> Interior Board
=> The Track......
=> Member's Build Threads
===> Your Mustang Story
Eleanor boards
=> All about the E cars
1974 and up Mustangs
=> General Late-Model Discussion
=> Mustang II
=> 1979-1993
=> 1994-2004
=> 2005-2009
=> 2010 +
=> Street or Track LLC
=> John's Place (ORP)
=> Midlife's Harness Heaven
=> Classic Recreations
=> Muscle Car Research LLC
Tools, Tip, and Classifieds
=> Classifieds (Mustang)
===> Wanted (Mustang related)
=> Classifieds (General)
===> Wanted
=> Services (All)
===> Wanted
=> Tools
=> Tech Articles
NON MUSTANG FORUMS....
=> StangFix Kitchen
=> Gum Flapper's Lounge
StangFix Member Approved Vendors
Loading...
